![]() | Home > Technical (L322) > Front airspring top cap forgotten how to get it off |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 101 ![]() ![]() ![]() |
Good evening Nick when I replaced mine recently, with complete new ones, I decided to strip the old ones just to see how they went together.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 670 ![]() ![]() ![]() |
They use STC 50554, which apparently is Loctite 648
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 69 ![]() ![]() ![]() |
Thanks both,
I assume we are all talking about this btw, the cover over it is plastic but they just pop off.
Yes, that's the one !
It’s threaded |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
That's true for practically all of them but I had both fronts done with complete struts a couple of months ago. When I had the second one done I got an Arnott strut and it came with the damper already fitted and all the clips for cables etc as well. The first one didn't have it and it was necessary to change it over. It was finally removed when the strut was off the car. One of the difficulties is when you try to remove it in situ everything turns. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3331 ![]() ![]() ![]() |
I’ve spent ages battling with one of these today!
Getting them to 250 to break the hold is the hard part IMO.. I think I used a 2KW hot air gun and a laser temperature gun, I couldn’t believe it just screwed off (with welders gloves) when it got up to temperature.
I'm still at it !!
Looks like it’s probably SEB500490:
Yikes!
Double yikes !!
If you've got the top of the strut off, turn the oven up as hot as it'll go, bung it in it for 20 mins to let it get hot then remove it.
