Home > Maintenance & Mods (L322) > Help on Adaptive Dynamics Please
Sonearly
I have the dreaded Adaptive Dynamics fault. It is intermittent, sometimes as soon as I set off, other times not for an hour of driving. The car has been fitted with the new improved wires and seems OK. This is the fault that shows on the Gap iid.
I have read that generally the tool says where the problem stems from, but unfortunately none of that info is available. Apart, obviously it may be control module itself.
Do I need to change the module or have others had this message and have a solution.
Not sure what next step should be so pray that the knowledge on here will assist.
Post #613466 22nd Nov 2021 10:09pm
Range Rover L322
Have you replaced the wires front and back? Time is definitely up on the back ones too.
Post #613473 22nd Nov 2021 11:12pm
Sonearly
No issue replacing the rear ones as well. What I was hoping was someone confirming they had the same fault code regarding the module error, especially if they had a wire issue.
Post #613476 23rd Nov 2021 12:21am
Sonearly
Replaced the Control Module and thankfully all back working as it should.
Post #613802 25th Nov 2021 5:04pm
mtaggart
United States 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Did you have to reflash the control module when you replaced it?
Post #656514 13th Feb 2023 7:31pm
