Home > Technical (L405) > Ticking or Knocking on Supercharger 5.0
TwoautobiographyTom
United Kingdom 2013 Range Rover Autobiography 5.0 SC V8 Loire Blue
Hi all,
Just picked this 2013 Supercharged Autobiography on 48k miles. Have noticed a slightly worrying noise coming from the engine when it's fully warm. It speeds up a bit with engine revs and then seems to disappear. Any thought on what it might be?
I'm worried it is timing chain guides and if it is that I need to return it to the dealer asap.
Video in link below.
Thanks,
Tom
Post #566130 2nd Sep 2020 6:47pm
Dolphinboy
I'm no expert on the 5.0L but it may be "chainslap" and need the tensioner looking at? Otherwise the chain guides is normally first point of call. (I take it these engines don't have VANOS a la BMW 4.4 V8??)
Post #566145 2nd Sep 2020 9:43pm
will_warne
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Although it’s difficult to be certain from the audio, it sounds like it could well be chain rattle due to failing tensioners. It’s certainly not right - it may ‘just’ be the supercharger coupling, but that’s still best part of £1k to sort... Is the car under warranty? If so, I’d be tempted to get the car sorted under warranty, rather than rejecting it - if it is the chain, fitting the latest parts should make the engine good for the next 150+k.
Post #566398 5th Sep 2020 8:05pm
TwoautobiographyTom
As an update for anyone that sees this. It was eventually diagnosed as timing chain tensioners. It still wasn't fixed after 6 weeks of giving it back to the dealer so rejected it and got my money back. The car had a 20k mile gap in its service history (grey area on LR's suggested service intervals) which I guess had something to do with it. Interestingly, there was another blue supercharged one up for £54k with 40k miles too and it has the exact same gap in service history. Decided to leave it and the hunt continues.
Post #569937 15th Oct 2020 8:39pm
Dolphinboy
wow, well done Will and i. Bang on the money. I seem to be getting better at diagnosing. Shows Ive just had waaaay too much experience on theses cars. Mr. Green Crying or Very sad Whistle
Glad you got your money back. The right one will come to you, take your time. Thumbs Up
Post #569950 15th Oct 2020 11:38pm
will_warne
Tom, sounds like you made the right decision - although it's a quite a big job to change the chain tensioners, we're talking about a week's work, so they should have been able to fix it comfortably in that time.
Best of luck with the search!
Post #569973 16th Oct 2020 9:09am
tpeat12
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Afternoon Gents,
Wondering if I could piggyback onto this thread.
I've just picked up a 5.0 Supercharged and contemplating the timing chain tensioner issue. I've taken a video of mine idling after a cold start and it doesn't seem too dissimilar to a normal idle sound bearing in mind that the engine cover is off. I also prodded on of the chains through the oil filler cap and there doesn't seem to be much play at all.
It's possibly something that i'll need to budget for in the future, but I don't think there's anything particularly worrying right now.
Anyway, I just wanted to see what you thought.
Cheers
https://www.youtube.com/watch?v=kDDQmKIVmuI
Post #615326 8th Dec 2021 3:17pm
What year is yours... ?
That video sounds like a diesel which is just what mine sounds like and it's had the chains done...
I think it's because they are direct injection...
Defo not like the slapping sound in the video of the OP... Thumbs Up
Remember you can only hear the chain noise with the bonnet up and standing in front of the car, listen from the drivers seat and it's near impossible to hear... Pete
-Click here for Thread-
Post #615342 8th Dec 2021 4:13pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
First one, wow that is the clearest I've heard the issue. I'm surprised they don't just fix it, yes there is a lot of room to be cleared but it isn't that big of a job and then the car is sellable. Very odd.
Second video I agree with Haylands, that sounds pretty 'normal'. Noisiest V8 I've ever owned, even with the bonnet shut. Best fix for it is a louder exhaust Razz
PS. A worn coupler you can also feel and hear when driving. There is just a slight delay in the supercharger, the wine is also less pronounced.
Post #615348 8th Dec 2021 4:24pm
tpeat12
Thanks for the rapid responses guys.
The car is a 2010 (10.5 i think) on 108k miles. It was serviced by main dealer up to around 80k, so i'm wondering if it's already been done. I tried to contact the service centre of the garage that looked after it (Hendy Land Rover in Christchurch), but they're not returning my calls.
Any suggestions for a fruitier exhaust? Wink
Post #615350 8th Dec 2021 4:34pm
Bl4ckD0g
Nowhere near all of them have this problem, although many internet sites may suggest otherwise. Often the 'issue' is perpetuated by those who don't even have one or experience this. In my opinion anything can fail on an engine. Just keep up with normal maintenance, and treat it nicely and it will be fine.
For an exhaust; I tend to use Full Throttle Performance, they are bespoke exhausts so you can have it how you want it. They get it spot on, no drone on the inside. Mine even was one in black as I didn't want shiny bits on my car...But being near Dunstable on the A5 is a little bit away from you near Christchurch (lovely part of the country)...I'm sure there are some decent performance specialist around there.
Post #615357 8th Dec 2021 5:00pm
tpeat12
I’ve seen a lot of posts stating that all of the cars will eventually have this issue, but do find that a bit hard to believe.
I’ll keep it in mind, but the car now lives in sunny glasgow - a long way from Christchurch 😂
Post #615366 8th Dec 2021 5:34pm
Bl4ckD0g
Lol I just spotted Christchurch in your post Smile Didn't look at the profile...
Post #615367 8th Dec 2021 5:41pm
tpeat12
I’ve just realised that this is the l405 group. I should have stated I’ve a L322 (but I presume everyone got that from the 2010 model year)
Post #615369 8th Dec 2021 5:47pm
