![]() | Home > Technical (L322) > no lights or blinkers 2005 L322 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
I presume you have checked fuses 9, 4 and 53 on front fuse board and the links 3 and 4 each rated at 50A. |
Obarnes Member Since: 08 Dec 2021 Location: Alabama Posts: 7 ![]() ![]() |
checked 4 and 9 but not the others. I will check per your suggestions. Thank you |
3 and 4 in the rear / boot ? |
Links 3 and 4 are to the right hand side of the fuses on the front fuse board. |
I will check all 50 amp fuses / thank you |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 77 ![]() ![]() ![]() |
Pretty certain it will be caused by a faulty lighting control module. It’s easy to access from behind the panel at the right hand side of the accelerator pedal. They frequently give problems this time of year due to ingress of damp.
Sorry, just notice you are in the US. I was referring to a rhd UK car. In you case it may be to the right of the passenger footwell. |
I believe you are correct / do you know who can refurbish a LCM ? or what kind of shop should I look for in the US ? Thank you |
In the UK there are several people advertising this repair service on eBay, so I would check there first. |
I will check EBAY / I found a refurbished for $175 |
