Home > Technical (L322) > no lights or blinkers 2005 L322
Obarnes
United States
My lights on my 2005 RR L322 87k miles have gone crazy. I can disconnect battery but no fix, fuses have been checked in glove box and in rear all appear good. The headlights wont turn on but the passenger side repeater stays on. Both fog lights not coming on, no blinkers and NO brake lights. Any thoughts would be greatly appreciated. Car is in great shape but no lights working. Thank you for any suggestions.
Post #616169 13th Dec 2021 6:09pm
I presume you have checked fuses 9, 4 and 53 on front fuse board and the links 3 and 4 each rated at 50A.
Post #616184 13th Dec 2021 7:35pm
Obarnes
United States
checked 4 and 9 but not the others. I will check per your suggestions. Thank you
Post #616187 13th Dec 2021 7:48pm
Obarnes
United States
3 and 4 in the rear / boot ?
Post #616190 13th Dec 2021 7:53pm
Links 3 and 4 are to the right hand side of the fuses on the front fuse board. Thumbs Up
Post #616191 13th Dec 2021 7:57pm
Obarnes
United States
I will check all 50 amp fuses / thank you
Post #616201 13th Dec 2021 8:52pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Pretty certain it will be caused by a faulty lighting control module. It’s easy to access from behind the panel at the right hand side of the accelerator pedal. They frequently give problems this time of year due to ingress of damp.
Sometimes they can be fixed by dismantling and drying out. Otherwise you can send it off for a refurb for about £40-50
Post #616224 13th Dec 2021 9:54pm
Dtech
Sorry, just notice you are in the US. I was referring to a rhd UK car. In you case it may be to the right of the passenger footwell.
Post #616227 13th Dec 2021 10:22pm
Obarnes
United States
I believe you are correct / do you know who can refurbish a LCM ? or what kind of shop should I look for in the US ? Thank you
Post #616231 13th Dec 2021 10:29pm
Dtech
In the UK there are several people advertising this repair service on eBay, so I would check there first.
Post #616235 13th Dec 2021 10:44pm
Obarnes
United States
I will check EBAY / I found a refurbished for $175
Post #616238 13th Dec 2021 10:51pm
