![]() | Home > Technical (L405) > Adjusting soft close doors |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35749 ![]() ![]() |
found this in an old thread,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
The soft close is a motor in the bottom of the door… How it works and how you adjust it I’m not sure? Changed a few that had failed but have never been asked to adjust one… Cant be that difficult though!
shiversaint Member Since: 16 Aug 2021 Location: Sussex Posts: 9 ![]() ![]() ![]() |
Thanks, this does work to make it kick in, but is not an adjustment of any sort, you have to do this every time... |
Got it, I will have a look. Maybe the cable is stretched or something. |
Silverstone Member Since: 30 May 2024 Location: Silverstone Posts: 33 ![]() ![]() ![]() |
The driver's door soft close does not always work and I would like to lubricate or adjust as required. Is this easy to for someone with very basic DIY skills and if so - what do I do please? "There is no replacement for displacement" - W O Bentley |
B1GSO Member Since: 10 Jul 2024 Location: Dorset Posts: 1 ![]() ![]() |
Just had my driver's door soft close repaired. It was the "micro"? switch in the soft close motor so the motor was functioning but the door did not suck closed.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2712 ![]() ![]() |
The driver's door on my new to me MY21 often re-latches when opened from inside, usually requiring multiple attempts to get the door open even when on level ground.
Mine's rear doors have an enclosed spring attached to the door that pushes against the body when the door is nearly closed. This spring prevents soft-close from operating unless gentle pressure is applied to the door. The spring also pushes the door open away from the striker when opened. I need these springs on the front doors but the spring housing is molded into the door, not a simple screw attachment that could be duplicated on the front.
ss10 Member Since: 05 May 2025 Location: Reston, VA Posts: 24 ![]() ![]() ![]() |
Same here. Passenger side was intermittent and getting worse. In my case the deployable step would not close when the soft close did not function. Took the latch apart. Found one of the micro switches to not consistently make electrical contact. Looked for a replacement without any luck. Took a small syringe full of isopropyl alcohol stuck the needle inside the dust boot on the tiny plunger of the micro switch and squirted the fluid in there. Been working ok since. Edit: Lol! did not realize this thread was from 2021. |
I found a solution to mine's drivers door over zealous closing by placing a small sponge block between the pillar and the striker. I'll keep an eye out for a black rubber block that offers more resistance that won't need to protrude as much, but the sponge block is solving the issue. L405 D350 SE Carpathian Grey D5 19" rims |
