![]() | Home > Technical (L322) > Strange starting issue and limp mode under heavy acceleratio |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
Simple things first, has it ever had a fuel filter changed?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Any fault codes rearing up on a scan? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Ian Thompson Member Since: 29 Sep 2021 Location: Dover, Kent Posts: 20 ![]() ![]() ![]() |
I have only owned this for 3 months and have no info on if fuel filters have ever been changed.
I'd be taking it to a decent LR independent specialist for diagnosis. Avoid main dealers. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Any tips for a good specialist anywhere near Dover, Kent? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
I keep a record on Google Maps when I hear good reviews.
So to revisit this I have now worked out this only happens when I get very low on fuel then lasts for a few days after I fill up, slowly returning to normal. Anyone got any clues on what this indicates? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3381 ![]() ![]() ![]() |
You need to get this checked by a specialist or get a GAP IID and read the codes. Anything else is a shot in the dark 2012 TDV8 Vogue (L322) |
As above, get the codes read by an independent specialist - I gave you a list |
