Home > Technical (L322) > Strange starting issue and limp mode under heavy acceleratio
Ian Thompson
2011 4.4 TDV8 Vogue 86k miles
When pressing engine start button the engine turns over for a long time but does not fire then times out. Pressing button again the engines turns over for some time then eventually fires and sounds a little rough for a minute, a bit like a misfire that fades away. All is ok after that unless I use heavy acceleration when the engine management kicks in and I get the Reduced Performance message and the vehicle eventually can only maintain approx 10mph in any gear.
I'm thinking this sounds very like a fuel pump issue but which one if at all?
Ideas on an Xmas card please, or a postcard !!
Post #617193 21st Dec 2021 11:12pm
cass
Simple things first, has it ever had a fuel filter changed?
Any codes?
Post #617201 22nd Dec 2021 12:15am
DrRob
Any fault codes rearing up on a scan? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #617212 22nd Dec 2021 8:49am
Ian Thompson
I have only owned this for 3 months and have no info on if fuel filters have ever been changed.
I do not have any scanning capability to access any error codes (mmm, I spy a self Xmas present coming!)
Post #617221 22nd Dec 2021 10:03am
DrRob
I'd be taking it to a decent LR independent specialist for diagnosis. Avoid main dealers. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #617224 22nd Dec 2021 10:31am
Ian Thompson
Any tips for a good specialist anywhere near Dover, Kent? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
2004 TD5 Discovery 2 - gone
2002 Freelander 1.8 - gone
Post #617229 22nd Dec 2021 11:17am
DrRob
I keep a record on Google Maps when I hear good reviews.
Here you go:
East Kent Automotive Ltd.
Landmark Land Rover
Discovery Garage
AHL Engineering.
Only in order of distance from Dover. No prior personal experience of any of them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #617230 22nd Dec 2021 11:24am
Ian Thompson
So to revisit this I have now worked out this only happens when I get very low on fuel then lasts for a few days after I fill up, slowly returning to normal. Anyone got any clues on what this indicates? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
Post #626599 21st Mar 2022 11:02am
JayGee
You need to get this checked by a specialist or get a GAP IID and read the codes. Anything else is a shot in the dark 2012 TDV8 Vogue (L322)
Post #626600 21st Mar 2022 11:07am
DrRob
As above, get the codes read by an independent specialist - I gave you a list Whistle Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626603 21st Mar 2022 11:49am
