Home > Technical (L322) > 'Scandinavian' plug-in heater option? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Some years ago I fitted Kenlowe engine preheaters to 3 vehicles including a Discovery 1. Basically these heaters were 3kw electric heaters with an integral circulating pump that were fitted into the engine coolant circulating pipe work.
25th Dec 2021 12:30am |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 119 |
Something like this perhaps
25th Dec 2021 7:06pm |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 82 |
Thanks for the replies.
25th Dec 2021 11:29pm |
Dan_Veluwe Member Since: 04 Dec 2021 Location: Highlands ( Veluwe) Posts: 172 |
I had a DEFA heater in the cooling circuit. In my Terrano II (2.4 petrol), it fitted in a casting
26th Dec 2021 1:52pm |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 719 |
There should be an LR part for this as I had an engine block heater from the factory in my Canadian L322. 2021 P400 Silicon Silver AB
26th Dec 2021 3:30pm |
Looks like we're getting somewhere
26th Dec 2021 5:45pm |
I suspect the above heater was part prc9674 as above.
26th Dec 2021 6:39pm |
I guess THE question now is: does the 4.4 TDV8 cooling cycle has a coolant hose part of the engine thermostat-still-closed cycle that can be used to install an electric heater & pump?
26th Dec 2021 7:13pm |
The normal way to install an auxiliary heater fitted with an integral circulating pump is to install it in one of the hoses going to the heater. These hoses give uninterrupted coolant flow to and from the engine block.
26th Dec 2021 7:33pm |
Yesterday I was reading about the 4.4 TDV8 engine cooling in the workshop manual.
27th Dec 2021 9:28am |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 |
Plenty of others around - just type <engine> into google. |
27th Dec 2021 10:42am |
Installing a heater in parallel with either the egr or oil cooler would negate the thermostats installed in either circuit.
27th Dec 2021 1:14pm |
Sorry Spitfire is was a petrol engine not the TDV8 2021 P400 Silicon Silver AB Gone 2011 Bournville TDV8 VSE Gone 2008 Black Canadian HSE LUX |
27th Dec 2021 5:09pm |
There are printscreens from the pdf workshop manual.
28th Dec 2021 1:55pm |
