Home > In Car Electronics (L322) > Ignition won’t turn off, help! |
Deputy Member Since: 23 Nov 2021 Location: Maidenhead Posts: 33 |
My key in dash 👍 |
27th Dec 2021 6:05pm |
Is this a known issue?
27th Dec 2021 7:00pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
What position is your gear shifter in? Can you hear the solenoid clicking when you press the brake pedal?
28th Dec 2021 12:27am |
I can drive the car as normal so I can move the gear lever in any position you would normally. I just can’t turn the key anti-clockwise to switch off. It’s seized in position II, nothing else is wrong. |
28th Dec 2021 12:36am |
Right... For the key to turn in the ignition, first the ignition needs to know the car is in Park...
28th Dec 2021 1:07am |
Is there a cable between the ignition barrel on the dashboard, just left of the steering wheel, and the gear shifter? |
28th Dec 2021 1:42am |
I forgot to mention that the key barrel appears to be seized in position II BUT I can pull the key out of the ignition. I was able to drive around with the engine on and key out.
28th Dec 2021 10:47am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Worth a try spraying wd40 into the key barrel. I know people say you shouldn’t but I’ve always done it and never had any problems. |
28th Dec 2021 11:53am |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 332 |
Certainly, on the early cars, there is a cable that activates when the gear selector is moved from Park.
28th Dec 2021 11:58am |
Hi John, thanks. This is very helpful. |
28th Dec 2021 12:40pm |
Think you’re correct since there does appear to be a cable between ignition and gear selector. Ignition probably doesn’t know when it’s in P but when it’s in D, how come I can pull the key out? That’s what I found confusing. Is this be a replacement part or just a repair/ lubricant application to keep it from sticking? |
28th Dec 2021 2:03pm |
Has anyone tried this fix?
30th Dec 2021 12:38am |
