![]() | Home > Maintenance & Mods (L405) > Deployable steps fitting issues help its driving me insane ! |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Do they need to be activated via the CCF file? 2011 TDV8 Vogue SE |
Discodazzla28 Member Since: 08 Jun 2021 Location: Wolverhampton Posts: 17 ![]() ![]() ![]() |
That’s sort of my question really? I’m not sure if they should just work or if I need to configure??? |
Any ideas greatly appreciated |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
On a 13MY they are simple plug and play... How have you purchased the parts? |
OK, just reread your first post... Proposing you have been sold the correct module?
Thanks Craig
the car has been left to sleep locked and came back the next day and no joy. I haven’t done a hard reset yet. Haven’t actually disconnected the battery since I brought it. Assume I can just disconnect the one on the boot spare wheel well?
No, the 13MY doesn't have diagnostics for the steps or tow bar... Treat the system as a stand-alone system, sir...
I have had the fuse out and nothing different |
Explain to me what you have done/fitted and where about on the car sir... |
ok so I tried as follows:
Where was the plug in your vehicle? Where have you mounted the ECU? |
as you look in the boot the plug was the far right hand side, with a blank plate on it
Wire harness part ref - VPLWP0178
