Home > Technical (L322) > 4.4 TDV8 Throttle Body |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 274 |
Thanks both |
3rd Jan 2022 5:23pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
Easy enough to remove the intake pipe and not break the brittle plastic coolant pipe. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Jan 2022 7:25pm |
PyroJames Member Since: 28 Aug 2020 Location: cambridge Posts: 6 |
For all those that replaced the elbow did it fix the RP problem? Just wondering before I go and order a new LR022663! |
11th Feb 2022 6:17pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 223 |
Looks like the Restricted Performance message has happened on my car before. Not sure a cable tie counts as a long term fix but I’ve done 10K miles since buying the car and this has clearly been in place for a lot longer than that.
30th Jun 2022 11:53pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2661 |
Given that the throttle elbow is rigid plastic it's hard to see how a zip tie is doing much to hold it on. It's missing the lock ring which fits in the slots BTW. 2012 TDV8 Vogue (L322) |
1st Jul 2022 7:20am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1113 |
The locking ring is under that zip tie. |
1st Jul 2022 7:59am |
Sorry I was looking at the empty slots 2012 TDV8 Vogue (L322) |
1st Jul 2022 8:01am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1337 |
Funnily enough I had intake gunk appear beside mine. Cleaned it up a while ago and I've got more again and the DPF full message pop up yesterday (amber one saying see handbook) after I gave it an inspection. It's around the metal clip area. Can't imagine my DPF is actually full as I did 200 motorway miles last Friday and haven't been far since so, a regen would have happened.
1st Jul 2022 9:43am |
Gary, it has a double lipped green seal inside that leaks and nobody has managed to find a suitable seal to replace it with. I had to have a complete hose which has solved my leak. |
1st Jul 2022 10:45am |
I took mine off tonight and took a photo. Prompted the periodic clean and clean of the MAP sensor anyway (which was all gunked up). This must be what fails - the green seal partially collapses (see yellow areas).
1st Jul 2022 9:21pm |
Wow, the green seal on mine sits all the way in the slot with very little protruding.
2nd Jul 2022 5:55pm |
Yuk!. Checked mine today and it's loose' but not leaking so the seal must be working. No idea why this connector is not rubber with a jubilee clip. 2012 TDV8 Vogue (L322) |
2nd Jul 2022 5:58pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
Is there any possibility of fitting an o-ring on the housing? I don't know if there's room for one as I haven't had mine off for quite some time. |
2nd Jul 2022 10:05pm |
To be honest, I don't see how PTFE tape, rubber tape, self amalgamating tape or an o-ring wouldn't work as a seal instead. Take the double lip put and measure the diameter and thickness for an o-ring? All these things cost less than £1 so, worth a try before forking out nearly £200 on a new hose.
2nd Jul 2022 10:40pm |
