Home > Technical (L322) > Happy New GEAR!! Is it a healthy year for my gearbox?
Page 2 of 3 <123>
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Wow, it looks like you have some professional tooling for this job Very Happy
Didi you buy the valves directly from Sonnax? Did you do all the valves in the valve body? And also the valves in the pump cover? Thumbs Up
Post #618696 4th Jan 2022 5:08pm
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
I bought them on eba y and from suppliers on the web, sonnax only sells them to its sellers
Post #618697 4th Jan 2022 5:11pm
Rangie4fun
Did you also do the valves in the pump cover? Because that is a transmisson out job...
Was your gearbox behaving strange or what was your reason for this overhaul?
Post #618699 4th Jan 2022 5:15pm
madcima
yes I changed that too, I don't want to have more problems on the gearbox. since the problem is not the converter, however updated also that
Post #618701 4th Jan 2022 5:16pm
madcima
the first thing you notice is the consumption, the second the speed fluctuates, the engine brake is completely missing, after about 1000 km that I felt the rubbing, the gearbox went crazy, it was climbing and revving and dropping by itself at constant speed.
always on the sonnax site, there are also various problems and which tube to replace.
maybe the defects are not the same
Post #618702 4th Jan 2022 5:21pm
madcima
https://www.sonnax.com/tech_resources/132-...rse-or-tcc
https://www.sonnax.com/tech_resources/561-...ody-layout
Post #618703 4th Jan 2022 5:22pm
Rangie4fun
I also feel that consumption seems to decline. Revving is most of the time very stable. Only at 70 kmh it sometimes goes up by 50-100 rpm. That yours did go bang in 1000 kms is bad luck. I will keep an eye on how mine behaves. The revving is hardly noticeable. In the mean time I'm going to dive into the Sonnax info you posted. Thank you! Bow down
Joep
Post #618705 4th Jan 2022 5:30pm
Rangie4fun
In the meantime I got a very friendly reply from a Sonnax Product Support Specialist Bow down regarding the Accumulator springs: For a RR they only have specs for the #376 plate valve body. The other plate valve bodies #659 and #802 have slightly different springs, but the #376 should do the job in any L322 3.0 D.
In my initial post I swapped the accumulator locations around. Looks better now, but stil not correct:
2nd clutch is: 65,5 mm and should be 60,452mm (definitely not correct, but don't have 1-2 slip or harsh shifts... Question
Intermediate clutch is: 60,5 and should be 60,452 mm (this might be correct I think with measuring tolerances)
OD clutch is: 65,5mm and should be 65,15mm (not correct)
Direct clutch is: 59,4 mm and should be 60,325 mm (not correct)
If the OD clutch Accumulator is not working correct, it can lead to 4-5 slip or harsh shifts; if the Direct clutch accumulator is not working correct then this could lead to 3-4 slip or harsh shifts. I do have a strange shift behaviour form 3-4 or 4-5 (I don't know exactly): even when not pulling hard it mostly goes up to 3000 RPM before shifting over, rather harsh and revs dropping to 1500 RPM. Going to try and see what gearshift it is.
Post #619001 6th Jan 2022 4:26pm
madcima
this is interesting
Post #619072 7th Jan 2022 8:03am
Rangie4fun
Now I wanted to see how my box and TCC behave. So I hooked up the IID and recorded a run from stand still (parking place) up the motorway.
Form what I learned from some posts of RRPHil (also on RangeRoversNet) the TCC should come in partially at say 40 kmh and then at 90 kmh full. But... as I checked mine it only came in full at 90 kmh. No partial TCC operation at lower speed?? Shocked
Could someone help me with this? As I was accelerating on the motorway I thought it might be the problem, but on lower throttle on normal roads it does the same: no partial TCC operation. What is wrong here? Any help much appreciated! Bow down
Joep
Post #619334 9th Jan 2022 5:35pm
RRPhil
The vehicle speeds that you’re mentioning are for the ZF 5HP24 transmission, which doesn’t have a torsional vibration damper in the LUC. The GM 5L40-E torque converter does, so its calibration may be quite different.
I’ve never seen measured results from the 5L40-E before, so I’d be interested to look at them. Are you able to capture them as a .csv file and post them up on here? Including the transmission output speed would be very useful, too.
Phil
Post #619370 9th Jan 2022 8:43pm
Rangie4fun
Thanks for your reply Phil! Thumbs Up
As the 5L40E does have a torsional vibration damper I would think that it might be more able to cope with earlier (partial) lockup of the TC without unwanted vibrations. Or am I thinking the wrong way round?
I cought up a CSV file but I couldn't work with it so I kind of made something out of it, which is in my previous post. I'm not experienced with reading and working with these CSV files so would be very helpfull. I will capture another file tomorrow and can post it after work.
I'd be very happy to upload the CSV file but unfortunately I don't know how to upload them as I only have a button to upload Photos. Is there a way to upload them? Can someone guide me? Bow down
Joep
Post #619383 9th Jan 2022 10:18pm
Rangie4fun
Hello Phil, recorded some more files yesterday, but as I came home yesterday my laptop was toasted. Big Cry Just only could log in with my cellphone but can't load up CSV files. I'm off to work and try to send files in a PM to you tonight.
Post #619526 11th Jan 2022 8:21am
Rangie4fun
Hello Phil,
Just sent you a PM regarding the CSV files.
Joep
Post #619612 11th Jan 2022 7:40pm
RRPhil
Joep,
I’ve attached the graphs produced from the measured data sets that you kindly sent through to me. Unfortunately, the “Hermagor Hasslacher” data set had a lot of data missing, so I haven’t been able to include that one.
As you say, there’s no evidence whatsoever of the torque converter lock-up clutch being activated in a ‘controlled slip’ mode. In fact, it only engages in 5th gear, and then only when you’re backing off the throttle.
According to RAVE, for the GM 5L40-E transmission:
Lock-up Clutch Mechanism
The Torque Converter Clutch (TCC) is hydraulically controlled by a solenoid which in turn is controlled by PWM signals from the EAT ECU. This allows the torque converter to have three states of operation as follows:
• Fully engaged
• Controlled slip variable engagement
• Fully disengaged
I hope you don’t mind me saying that you appear to have a very heavy right foot 😊. Is there any chance you could capture some data at light throttle openings? The LUC should engage in 3rd, 4th & 5th gears.
Phil
Post #619877 13th Jan 2022 8:39pm
Page 2 of 3 <123>
