Home > Maintenance & Mods (L322) > I assume my plenum is fubar? |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
Hi Guys,
9th Jan 2022 8:25pm |
Ah is that confirming it fubard then? Time to see if the place I bought it from is feeling helpful, otherwise is time. Encourage alternative fuels, use all the petrol!
10th Jan 2022 12:21am |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 |
https://www.ebay.co.uk/itm/RANGE-ROVER-4-4...635-2958-0
10th Jan 2022 7:57am |
These look to be a pattern part with throttle body
10th Jan 2022 9:02am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2701 |
Not is stock at the last link ( otherwise I'd be tempted just to avoid cleaning mine) 2012 TDV8 Vogue (L322) |
10th Jan 2022 9:59am |
In stock on there eBay listing
10th Jan 2022 10:34am |
Says 'this item is out of stock' on the yellow header. 2012 TDV8 Vogue (L322) |
10th Jan 2022 10:36am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
"Ah is that confirming it fubard then? Time to see if the place I bought it from is feeling helpful, otherwise is Big Cry time."
10th Jan 2022 11:22am |
Yup only had it a couple of months. The dealer has accepted responsibility , so looks like I can save my pennies for now. Encourage alternative fuels, use all the petrol!
10th Jan 2022 11:31am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
The performance should definitely not be underwhelming.
10th Jan 2022 11:45am |
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 |
I managed to extend the life of mine with epoxy for a good few months but , with hindsight, I should have renewed it ages back. A few days back got one from Maltimgs and sorted it. Result = soot levels low, better mpg, smooth power yield and peace of mind. The gunge in the old one and the throttle body was staggering . 60plus k miles and no supermarket diesel used. I reckon a good 5% plenum volume occupied by gunge. ----------------
10th Jan 2022 11:36pm |
Buildup of black gunk seems to be a normal condition for these intakes even when working correctly. Even if you clean or replace the plenum to remove this build-up there will be still deposits within the manifolds and around the intake valves which you can't get to without a significant teardown of components. It's a good idea to regularly clean the MAP sensor as when this gets blocked it definitely caused a bit of hesitancy on low end pickup and maybe also remove the throttle body to ( carefully) clean this and the EGR pipe that sticks into the Plenum. Also just how long before it gets a new coat of gunk when you have cleaned it. I was watching my EGR valve position and operation via the GAP IID tool and cruising on the M-way it's open most of the time and only closes on fairly hard acceleration and overrun. 2012 TDV8 Vogue (L322) |
11th Jan 2022 10:16am |
👍🏼 Thanks for info ----------------
11th Jan 2022 3:38pm |
This seems to be working on mine
15th Jan 2022 3:08pm |
