![]() | Home > Maintenance & Mods (L322) > I assume my plenum is fubar? |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Hi Guys,
Ah is that confirming it fubard then? Time to see if the place I bought it from is feeling helpful, otherwise is |
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/RANGE-ROVER-4-4...635-2958-0
These look to be a pattern part with throttle body
Not is stock at the last link ( otherwise I'd be tempted just to avoid cleaning mine) 2012 TDV8 Vogue (L322) |
In stock on there eBay listing
Says 'this item is out of stock' on the yellow header. 2012 TDV8 Vogue (L322) |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 771 ![]() ![]() |
"Ah is that confirming it fubard then? Time to see if the place I bought it from is feeling helpful, otherwise is Big Cry time."
Yup only had it a couple of months. The dealer has accepted responsibility |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7930 ![]() ![]() ![]() |
The performance should definitely not be underwhelming.
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 ![]() ![]() ![]() |
I managed to extend the life of mine with epoxy for a good few months but , with hindsight, I should have renewed it ages back. A few days back got one from Maltimgs and sorted it. Result = soot levels low, better mpg, smooth power yield and peace of mind. The gunge in the old one and the throttle body was staggering . 60plus k miles and no supermarket diesel used. I reckon a good 5% plenum volume occupied by gunge. ----------------
Buildup of black gunk seems to be a normal condition for these intakes even when working correctly. Even if you clean or replace the plenum to remove this build-up there will be still deposits within the manifolds and around the intake valves which you can't get to without a significant teardown of components. It's a good idea to regularly clean the MAP sensor as when this gets blocked it definitely caused a bit of hesitancy on low end pickup and maybe also remove the throttle body to ( carefully) clean this and the EGR pipe that sticks into the Plenum. Also just how long before it gets a new coat of gunk when you have cleaned it. I was watching my EGR valve position and operation via the GAP IID tool and cruising on the M-way it's open most of the time and only closes on fairly hard acceleration and overrun. 2012 TDV8 Vogue (L322) |
👍🏼 Thanks for info ----------------
This seems to be working on mine
