Home > Maintenance & Mods (L322) > Strange metal scraping noise - Help |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
Sounds very much like a brake dust shield to me. Splashing through puddles prob finished it off.
13th Jan 2022 11:39pm |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 50 |
that will be the handbrake-shoe retaining spring trapped between disc and brake backplate. the retaining washers on the end of the pins rust through so springs pop off and get stuck there. sounds awful, but no bigee. push backplate inwards with a screwdriver through wheel spokes to release it. new pins required, thats all. |
14th Jan 2022 12:17am |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 922 |
While your at it mate get some securing pin plates to hold the pin into place like a normal hand brake set up. Land rover decided to miss this washer and make it inside the brake dust shield itself |
14th Jan 2022 4:11am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
Thanks gents will crawl under her in the morning early. Is it a fix I can do to get me driving again without getting the pins?
14th Jan 2022 2:32pm |
You'll need to take the rear brake caliper off so you've got some movement in the disc to get the pin out. You can drive it without the locating pins but all you'll do is chew the rear shoes up and notice that your hand brake will be somewhat ineffective.
14th Jan 2022 4:06pm |
Done pretty much the same way as this mate
14th Jan 2022 4:09pm |
