![]() | Home > Technical (L322) > Happy New GEAR!! Is it a healthy year for my gearbox? |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044
The torque converter is fully locked because the engine & turbine speeds are identical. At this point, though, the throttle input is down to 30-40% because you’re backing off, so the TCC PWM solenoid doesn’t appear to be at maximum pressure.
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169
Thanks Phil for the explanation. |
I’ve had a look at the last four runs that you sent to me.
Hi Phil
I don’t see any evidence of an issue with the TCC PWM solenoid. On the contrary, the LUC appears to be responding exactly the way you’d expect to the solenoid signal. I think if you want to see the LUC operating in 3rd, 4th & 5th gears you will need to get the fluid temperature up to ‘normal’ i.e. 90°C+
Hi Phil,
Hi all. Sad news now; I got the Trans Failsafe Progr. message and car is only shifting up to 3rd now and stays there (no up- or down shifts). |
| All times are GMT |
