Home > Technical (L322) > Red Warning light - how far would you drive?
jackie-o
Netherlands
Hi,
So Red Restricted performance came on out of nowhere, 2011 4.4TDV8
Car drives holding 60 on the motorway but there is a very obvious lack of power.
Unfortunately i dont have anOBD scanner.
I have about 45 miles to get home, would you keep driving or better to park it?
As always, thankful for any replies!
J RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #582660 7th Feb 2021 10:25am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I had the red DPF full light come on once when I was halfway to work Restricted performance kicked in but I found using the paddle shifts helped. In total I would have driven about 30 miles getting it to work and then on to my Indy and it was fine. Obviously if your 45 mile trip can be done on roads no faster than 50MPH it will feel more comfortable than if you were on a major motorway. 2011 TDV8 Vogue SE
Post #582663 7th Feb 2021 10:54am
GGDR
Most likely an air/boot leak.... But could be something else...
Check your oil level as a basic thing...
Check boost hoses as best you can where you are..
Switch off leave it for a bit then maybe the code will clear?
Otherwise call a roadside assist who would have a code reader
Good luck. Cheers, Greg
Post #582666 7th Feb 2021 11:28am
jackie-o
Netherlands
@dennij; this is the red RP light, have not haf any DPF lights, thankfully.
@ Gregg, I suspect something similar. The 4 short hoses were replaced a year ago along with the EGR and a bunch of gaskets. Could it be MAP or MAF sensors perhaps?
Anyway, I followed your advice and turned the car off for 20 min. Started up again and warning gone. Drove home fine. Will take it to indy tomorrow to read fault codes...
Only thing i noticed is that fule consumption was up about 30 % on the way home, just following the instantaneous reading on the screen RR Vogue 4.4 TDV8 - 11
Post #582668 7th Feb 2021 11:44am
jackie-o
Netherlands
And oil/filter change was done about two weeks ago so that shouldn’t be it I’d hope RR Vogue 4.4 TDV8 - 11
Post #582669 7th Feb 2021 11:46am
GGDR
ok well good you got home Thumbs Up
Time to invest in an IID. ?
You can get cheaper code readers too.
Once I was on the motorway and a restricted came up out of nowhere.
Motorway way busy and no hard shoulder and it wasn't a good time to drop from 70mph to 50mph.
I cleared the code with three clicks as I has the IID running and poof - gone and back to 70mph so it was a fantastic thing to have at hand.
I waited for the error to return but it never did.
I would not own a RR without an IID or other code reader, it''s essential kit.
No idea what 'normal' people do!! Shocked
. Cheers, Greg
Post #582672 7th Feb 2021 12:52pm
DrRob
Ditto. IID is permanently kept in the glove box. Never leave home without it Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #582679 7th Feb 2021 1:27pm
jackie-o
Netherlands
@Greg, Rob; IID tool on the shopping list!
Strange tho this time as I just had the car to my trusted indy and no faults logged.
He said it could be the cold weather (-12 here at the moment) and that the fault has cleared itself.
His advice was to take it out for a proper thrashing and see if the fault comes back. Otherwise forget and move on...
600 mile+ roadtrip planned this weekend so fingers crossed Yawn RR Vogue 4.4 TDV8 - 11
Post #582813 8th Feb 2021 2:21pm
Ian G
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
You mean you're supposed to stop? Embarassed
Post #583051 10th Feb 2021 3:22am
supershuttle
I know this is an old thread but a search on restricted performance finds plenty, maybe to much. After I had the car serviced the red triangle appears even on a modest journey (40 miles).I took it to my local Indy yesterday and they charged me 300 quid to provide and change a 60 quid sensor. I’m not a tools man but I do have an IDTool is there something simple I can check or is it a case of a few hundred quid more with my fingers crossed ? Geoff
Post #619965 14th Jan 2022 4:18pm
dennij
Can I assume that before the service there was no issue with restricted performance popping up? Normally it’s caused by an air leak on the intake, you could start by checking the simple things like air filter screwed down properly, pipe from air filter box to first jubilee clip etc. If this issue has only come on since the service was done then it might be worth asking the garage to check they haven’t left anything off. 2011 TDV8 Vogue SE
Post #620092 15th Jan 2022 6:57pm
JayGee
IME it’s very unwise to run these cars and not own a GAP IID tool. It’s like not having a spare tyre or breakdown cover. My short time under the bonnet has led me to have a very poor opinion of the wiring looms used in these cars. Lots of exposed insulators on the ends of connectors that is causing them to get hard and fragile which if disturbed during clumsy servicing leads to breaks in circuits and reduced performance faults.
Back to the original question - without knowing the specific fault it’s not possible to say if it’s safe to drive. 2012 TDV8 Vogue (L322)
Post #620136 16th Jan 2022 9:57am
supershuttle
Thanks,
I do have an IDTool and used it to reset the fault once other times it has cleared itself while parked up. I took it back to the garage that did the service but they just replaced the exhaust gas temperature sensor. Needless to say fault is still there 😀 Local Indie is where I had it serviced. Geoff
Post #620165 16th Jan 2022 1:10pm
supershuttle
Read the codes from the IIDTool it says- P040D(2F) it also says Exhaust gas temperature sensor A circuit high.
Anyone got any ideas, if I turn ignition off whilst "Restricted Performance" warning is active it runs on for a second or two. If I reset it with IIDTool then all is OK - until it comes on again (a good half hour). Is this in anyway messing with my DPF as it obviously can't do a region when limited to 50 or so mph. I assume when the warning isn't showing its regaining as normal. Geoff
Post #620184 16th Jan 2022 4:04pm
