Home > Technical (L322) > Red Warning light - how far would you drive? |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
I had the red DPF full light come on once when I was halfway to work Restricted performance kicked in but I found using the paddle shifts helped. In total I would have driven about 30 miles getting it to work and then on to my Indy and it was fine. Obviously if your 45 mile trip can be done on roads no faster than 50MPH it will feel more comfortable than if you were on a major motorway. 2011 TDV8 Vogue SE |
7th Feb 2021 10:54am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Most likely an air/boot leak.... But could be something else...
7th Feb 2021 11:28am |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 224 |
@dennij; this is the red RP light, have not haf any DPF lights, thankfully.
7th Feb 2021 11:44am |
And oil/filter change was done about two weeks ago so that shouldn’t be it I’d hope RR Vogue 4.4 TDV8 - 11
7th Feb 2021 11:46am |
ok well good you got home
7th Feb 2021 12:52pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
Ditto. IID is permanently kept in the glove box. Never leave home without it 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Feb 2021 1:27pm |
@Greg, Rob; IID tool on the shopping list!
8th Feb 2021 2:21pm |
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 |
You mean you're supposed to stop? |
10th Feb 2021 3:22am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
I know this is an old thread but a search on restricted performance finds plenty, maybe to much. After I had the car serviced the red triangle appears even on a modest journey (40 miles).I took it to my local Indy yesterday and they charged me 300 quid to provide and change a 60 quid sensor. I’m not a tools man but I do have an IDTool is there something simple I can check or is it a case of a few hundred quid more with my fingers crossed ? Geoff |
14th Jan 2022 4:18pm |
Can I assume that before the service there was no issue with restricted performance popping up? Normally it’s caused by an air leak on the intake, you could start by checking the simple things like air filter screwed down properly, pipe from air filter box to first jubilee clip etc. If this issue has only come on since the service was done then it might be worth asking the garage to check they haven’t left anything off. 2011 TDV8 Vogue SE |
15th Jan 2022 6:57pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2650 |
IME it’s very unwise to run these cars and not own a GAP IID tool. It’s like not having a spare tyre or breakdown cover. My short time under the bonnet has led me to have a very poor opinion of the wiring looms used in these cars. Lots of exposed insulators on the ends of connectors that is causing them to get hard and fragile which if disturbed during clumsy servicing leads to breaks in circuits and reduced performance faults.
16th Jan 2022 9:57am |
Thanks,
16th Jan 2022 1:10pm |
Read the codes from the IIDTool it says- P040D(2F) it also says Exhaust gas temperature sensor A circuit high.
16th Jan 2022 4:04pm |
