![]() | Home > Technical (L322) > PRE HEATER PROBLEM |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Erm, leaking fuel line?
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Is it heating as well as dumping fuel? Without wanting to state the obvious, but I will, it sounds like you have a leak. Can you see where it is coming from? Previously..
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
Could be leaking at the connection of the fuel pipe to the fbh or it could be un-burnt fuel coming out of the exhaust.
bizzybus Member Since: 19 Aug 2012 Location: merseyside Posts: 53 ![]() ![]() ![]() |
Thanks Chaps, It is heating the cabin but i havent had a look yet to see werabouts it is coming from,not had much to do on this motor yet so not familiar with were things are,i was wondering if the fbh does not light does the unburnt fuel get dumped out of its exhuast? i will check fuel lines for leaks,the leak seems to be from rear of engine area |
FBH is at the rear of the engine compartment on the nearside (passenger side) of the car - I say rear of the engine compartment, but I believe that the best way to get to it is either to remove the battery and battery tray or the inner wing lining - possibly both.
Thanks Simon yes that was my thought as its working |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8761 ![]() ![]() ![]() |
You can get it through the battery tray as simon says, but the easiest way is to remove the wheel arch liner on the passenger side, can be done with the wheel on and the car on the ground. This gives a pretty decent view of the FBH and pipework, still tight though.
Thanks for the tips chaps i will post back when job done (SEE WHAT HAPPENS WITH HEATED SEATS) |
Was going to say, it is much easier to see from the wheel arch, the exhaust should look like this:
Scottw105 Member Since: 18 Jan 2022 Location: Manchester Posts: 1 ![]() ![]() ![]() |
Hi guys I have a Range Rover Autobiography SDV8 2015 and there is a smell of diesel in the cab, I have found that there is a pipe behind the left (n/s) front wheel dripping fuel, I assume this is some sort of overflow pipe from the cabin heater, could anyone shed any light on what this issue could be? |
