Home > Maintenance & Mods (L322) > 2010 l322 front brake pads by meyle
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Hi all got new disc and pads from meyle via Advanced motor factors and Look great quality, but 2 of the front pads have this big round lump of metal riveted to it. I'm assuming it must be some sort of sound damper but not sure if this pad should be fitted inboard side or outboard side of caliper. Has anyone come across this before.
Post #620569 19th Jan 2022 12:46pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If they're sliding calipers on yours rather than Brembos, I'd suggest the inboard / piston side - as that's the side with the lowest weight.
However, it's only an "educated" assumption. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #620575 19th Jan 2022 1:57pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
That sounds odd. Do you have a photo of what it is that is on those pads? You have the Brembo big brake kit upfront right with that MY?
Post #620577 19th Jan 2022 2:05pm
dhallworth
No, the 2010MY 3.6's didn't have 4 or 6 pot Brembo brakes. They were fitted with twin piston sliding calipers.
They were the change over between the 4 and 6 piston calipers.
Post #620579 19th Jan 2022 2:36pm
Landmark
Pic as requested hopefully
Strange metal lump riveted to pad.
Post #620601 19th Jan 2022 7:23pm
Landmark
Post #620602 19th Jan 2022 7:25pm
Bl4ckD0g
Yes you are right about that dhallworth. How do you know it is a 3.6? I couldn’t see the model mentioned 🤣
Post #620622 19th Jan 2022 10:37pm
dhallworth
His car profile says 2010 TDV8, majority of 2010’s were 3.6’s and the description of the brake pads gave it away. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #620624 19th Jan 2022 10:42pm
Landmark
Model
3.6 tdv8 aa chasis vin
Post #620625 19th Jan 2022 10:45pm
Bl4ckD0g
Awww yes annoyingly you can’t see those profiles on the mobile version of the website. But yes i normally put the metal parts on the side of the piston for those type of pad. On Audi they help Center and attach the pads.
Post #620626 19th Jan 2022 10:59pm
Landphil
For what it’s worth on my RRS, which was a 2013 model, the pads with the lump went on the outside of the disc.
Post #620629 19th Jan 2022 11:07pm
Landphil
Found a photo
Post #620631 19th Jan 2022 11:17pm
Andy
I have the 2010 3.6 with the sliding TRW calipers. I’m trying to order a set of brake pads and discs for the fronts but without taking the wheel off, I can’t tell if it’s 344mm or 360mm discs. I’ve offered up a tape measure but it’s difficult through the wheel.
Can anyone advise? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #620684 20th Jan 2022 1:52pm
Landmark
If your chassis begins with aa then normal calipers. Most of this year had no Brembo.
Post #620686 20th Jan 2022 2:13pm
Andy
It is AA
I’m looking at the TRW as the calipers are made by TRW so probably the most suitable 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #620687 20th Jan 2022 2:16pm
