Home > Technical (L322) > 4.4 TDV8 Vibration/Rumble - RPM related |
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 69 |
Hi,
21st Jan 2022 2:53pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
just read you other post UJ is also a likely culprit 2012 Vogue 4.4 TDV8 - Current
21st Jan 2022 4:29pm |
Hi,
21st Jan 2022 5:22pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 915 |
Measure & record engine speed, turbine speed, output speed and the EDS 2 solenoid current vs time using IIDTool or similar and analysis of the results will tell you whether it’s the TC LUC causing the vibration. Never seen results from an 8-speed before, so would be interesting
21st Jan 2022 5:53pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 766 |
HP jr
21st Jan 2022 7:31pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I’ve experienced similar too.
22nd Jan 2022 11:56am |
If I were to describe it,
23rd Jan 2022 4:21pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2318 |
There are lots of heat shields that will resonate if touching something. |
23rd Jan 2022 8:52pm |
Is it possible....
24th Jan 2022 7:33pm |
@RRPhil - thanks. Not invested in IIDTool yet (only had the car since October) - top of my list so will follow advice and report back!
27th Jan 2022 7:56pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 225 |
Did you check heat shields?
27th Jan 2022 8:06pm |
Yep heatshields checked - I couldn't see any issue. I had all the mid ones off when I changed the centre prop bearing.
27th Jan 2022 8:10pm |
Checked my shields too. No obvious problem.
28th Jan 2022 9:17am |
Some more insight into symptoms...
30th Jan 2022 5:45pm |
