![]() | Home > Maintenance & Mods (L322) > 2011 4.4 TDV8 Alternator charge volts ? |
Should be around 14.5v unloaded ( no lights, heated seats etc) - sounds like it needs replacing. 2012 TDV8 Vogue (L322) |
Ttrees Member Since: 08 Jan 2022 Location: Lincolnshire Posts: 13 ![]() ![]() ![]() |
Thanks thats what i was expecting but i know these smart alternators charge at different rates |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 488 ![]() ![]() ![]() |
The main noticeable difference is they take longer to kick in from startup.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 830 ![]() ![]() |
I see mine vary from 13.8 up to 14.9v
Thanks
Worth doing the water pump while you are at it. 2012 TDV8 Vogue (L322) |
I know i will have most of the work done to get to the pump but are they prone to fail then ? |
No more prone than any other waterpump but they are not that expensive and why risk it? 2012 TDV8 Vogue (L322) |
Ok thanks i will have a look |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I’d personally say it’s best to do it. Stripping down to be able to replace the alternator is a pita job so not having to do it more than once (or twice in your case) makes it worth the expense.
I get what you are saying although there is not much to go wrong with them except the bearings ill see if i can get it striped to the point of having a good look at the pump to see if its running nice and smooth then if needed i can get one before next weekend when i will be fitting the new alt belts and puleys.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
Is that a water pump? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
My 112k (at the time) 3.6TDV8 water pump wasn't leaking, but there was fairly significant play in the bearings, so I used the opportunity whilst everything was apart to replace it. Also did all of the aux belt tensioner pullies as they had play and noise.. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2686 ![]() ![]() |
Water pump bearings eventually fail which leads to the seal leaking. My 4.4's alternator has just failed at 150K Kms so I'll replace the water pump as well as all the idlers and tensioner to avoid any of them failing which could leave me stranded. |
