Home > Maintenance & Mods (L405) > Dodgy sunblind
Van Diesel
United Kingdom 2014 Range Rover Vogue SE SDV8 Mariana Black
Dodgy sunblind
Anyone know whats going on with this blind in the pano roof. When it passes its first stage of opening, instead of the blind material staying horizontal, it drops down and remains in this position all the way back, resting near the headrests on the back seat.
Upon closure, it stays like this until the last stage where it takes up the slack and returns to normal. Quick fix is to leave it closes all the time, but would like to put it right. Any ideas?
Post #620515 18th Jan 2022 11:03pm
Sorry sir, ive not had the pleasure of repairing one yet... Whistle
Post #620519 18th Jan 2022 11:44pm
something is sticking .. try a bit of lubrication .. ... - .- -.
Post #620538 19th Jan 2022 9:11am
Van Diesel
Do you think? It starts to sag as soon as it starts to open, then the further it goes back the more it drops.
Should there be runners on each side of the blind that keep it tort as is moves back? 2021 Defender 110 D300
2014 FF 4.4 SDV8
1986 3.9 V8 90 Pick Up
2011 FF 4.4 TDV8 (Gone)
2008 FF 3.6 TDV8 (Gone)
Post #620618 19th Jan 2022 10:07pm
it sounds like something is sticking for some of the way until it gets to the end and then loosens up ...
as it retracts try holding the front back a bit..
theres a fair bit of info in the WM that might help you.. ... - .- -.
Post #620620 19th Jan 2022 10:17pm
Van Diesel
Thanks Stan, I'll have a look at the weekend and a read of the WM in the meantime. 2021 Defender 110 D300
2014 FF 4.4 SDV8
Post #620628 19th Jan 2022 11:07pm
Further looking at your pic... I'm guessing the roller must be sprung loaded and yours has jumped the spring? i would think the front bar is motorized which allows the rear to roll in and out against a spring??? Thumbs Up
Post #620643 20th Jan 2022 12:52am
Van Diesel
Had a bit more of a look today and can see something is different on one side to the other. Took a couple of pics when the sun blind is fully open and the mechanism on one side seems to be sitting higher in the top rail. This also seems to be the side that doesn't sit right when it's closed.
A bit of a small place to get into with your fingers but pretty certain this is where the problem lies?
First pic is the good side IMO
The second pic where you can see what looks like a wiper blade over the blind is also present on the other side but tucked right down out of sight. 2021 Defender 110 D300
2014 FF 4.4 SDV8
Post #621111 23rd Jan 2022 5:34pm
Van Diesel
Following my above post I decided to tackle this today. A pause for thought...........what if my assumption is wrong and its the other side thats seated incorrectly.
If anyone has a roof blind and are feeling generous, could they have a look at theirs and see how each side sits, preferably with a couple of pics?
Failing that I'll need to befriend a local owner of a similar car and ask if I can have a look at theirs. Laughing
Post #621911 30th Jan 2022 10:17pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
This is on the right side:
and this on the left:
Post #621944 31st Jan 2022 12:00pm
Van Diesel
Thanks for these pics, looks like its the left side thats the problem then.
Just got to work out how to get and move it back in place without doing any further damage.
Post #622274 2nd Feb 2022 10:35pm
Van Diesel
I know this is my problem but I may be getting somewhere. In the pics I posted of left and right side, the left pic shows a bar sticking up that looks a bit like a wiper blade.
A bit more digging and I think this bar should be attached to the sun blind. Probably along the first seam of the blind.
Saw this second hand one on Ebay and the picture suggests it could be. Thinking it now its become detached and ended up wedged at the back of the mechanism??
New car to us but could the previous owner not have used the blind for a long time and then a few recent button presses has upset it?
Pic attached for item on ebay. Would anyone be able to give theres a prod and see if theres a rigid bar in a similar place. Think this would keep the blind tort and stop it from sagging?
2014 FF 4.4 SDV8
Post #622288 2nd Feb 2022 11:11pm
adara
Actually there are 2 bars, as you can see in the picture:
Post #622330 3rd Feb 2022 1:09pm
there are step by step instructions in the WM.. ... - .- -.
Post #622336 3rd Feb 2022 1:51pm
Van Diesel
Thumbs Up Thumbs Up Thumbs Up
Post #622366 3rd Feb 2022 8:34pm
