Home > Technical (L405) > Oil Dilution is it covered under LR warranty?
Page 2 of 3 <123>
Bluebird
Wales 2016 Range Rover Autobiography SDV8 Santorini Black
I can do , but I have the 12 month warranty and an extended warranty with Grange, the last thing I want is that I have broken the warranty agreement. I also paid for an annual service agreement. They get you all ways.
Post #621131 23rd Jan 2022 7:37pm
Bluebird
Offered £36k for car - bought for 3 months ago for £45k so the dealers can do one. Will do more mileage to avoid the problem .
Post #621268 24th Jan 2022 9:08pm
Kot
Dont worry about it, buy a vacuum pump and do the oil changes yourself when it tells you. 2018 SE SDV8 4.4 Byron Blue
Post #621271 24th Jan 2022 9:20pm
DrRob
Draper do a cracking one that holds more than enough to empty the sump. Doing mine at weekend Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #621272 24th Jan 2022 9:38pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
For the numpties - ie folk like me - how do you do an oil change using a vacuum pump?
I've seen this in the wiki: https://www.fullfatrr.com/forum/topic43994.html
... but "pump" suggests I don't have to crawl under the FF. What do I put here then?
Post #621318 25th Jan 2022 10:37am
wiki? ... - .- -.
Post #621319 25th Jan 2022 10:40am
DrRob
Basically you pump the oil out using a hand powered vacuum pump.
All done from on top of engine so no crawling on the floor like a baby Rolling with laughter
Have a look here (L322 4.4 TDV8) but same in an L405:
https://www.fullfatrr.com/forum/topic41966...oil+change
A few of us use the Draper Expert 10L one Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #621320 25th Jan 2022 10:55am
GAC23
I looked but could only find ones where the oil is drained, @Stan.
Am I being daft - always possible?
And thank you, @DrRob. What do I put here then?
Post #621321 25th Jan 2022 10:56am
GAC23
Looks so easy, even I can do it. Rolling with laughter
Where on the engine do you "plug" the pump in? What do I put here then?
Post #621323 25th Jan 2022 11:04am
Kot
https://www.drapertools.com/product/77057/...extractor/
Search, you can get them for £125 on eBay etc etc
Look at the pictures in the links Dr Rob posted its pretty clear where you connect to. 2018 SE SDV8 4.4 Byron Blue
Post #621331 25th Jan 2022 11:36am
GAC23
Thanks, @Kot.
Already looked at the pics. Need to study them more I think. What do I put here then?
Post #621339 25th Jan 2022 11:53am
Landphil
£126 on Amazon
Post #621355 25th Jan 2022 4:35pm
Landphil
Don’t throw the box away until you’ve used it a couple of times, my first one failed half way through the job but Amazon replaced it.
Once you have done it once you will never crawl under the car again to drain the oil.
Post #621357 25th Jan 2022 4:38pm
Bluebird
Looking at the LR guidelines it states that the salesperson should ask the customer the type of mileage they will undertake before deciding what different fuel type car to buy. In the financial sector if options were not recorded there would be a successful claim for miss selling. I was not advised of the issue of oil dilution and short journeys , strange how LR can get away with it. Also they keep claiming it is not mechanical problem but blaming your driving journeys. Another way of passing the buck.
Post #621937 31st Jan 2022 10:52am
supershuttle
I’m not a tools man anymore (age) so I bought the oil and just took it to a local garage and they changed the oil for twenty quid. I didn’t bother with filter. Geoff
Post #621949 31st Jan 2022 12:19pm
Page 2 of 3 <123>
