![]() | Home > Technical (L405) > Oil Dilution is it covered under LR warranty? |
Bluebird Member Since: 30 Aug 2021 Location: Cardiff Posts: 98 ![]() ![]() ![]() |
Offered £36k for car - bought for 3 months ago for £45k so the dealers can do one. Will do more mileage to avoid the problem . |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1417 ![]() ![]() |
Dont worry about it, buy a vacuum pump and do the oil changes yourself when it tells you. 2018 SE SDV8 4.4 Byron Blue |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Draper do a cracking one that holds more than enough to empty the sump. Doing mine at weekend Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
For the numpties - ie folk like me - how do you do an oil change using a vacuum pump? I've seen this in the wiki: https://www.fullfatrr.com/forum/topic43994.html ... but "pump" suggests I don't have to crawl under the FF. What do I put here then? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
wiki? ... - .- -.
Basically you pump the oil out using a hand powered vacuum pump. All done from on top of engine so no crawling on the floor like a baby ![]() Have a look here (L322 4.4 TDV8) but same in an L405: https://www.fullfatrr.com/forum/topic41966...oil+change A few of us use the Draper Expert 10L one Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 25th Jan 2022 10:56am. Edited 1 time in total |
I looked but could only find ones where the oil is drained, @Stan.
Looks so easy, even I can do it. ![]() Where on the engine do you "plug" the pump in? What do I put here then? |
https://www.drapertools.com/product/77057/...extractor/ Search, you can get them for £125 on eBay etc etc Look at the pictures in the links Dr Rob posted its pretty clear where you connect to. 2018 SE SDV8 4.4 Byron Blue |
Thanks, @Kot.
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
£126 on Amazon |
Don’t throw the box away until you’ve used it a couple of times, my first one failed half way through the job but Amazon replaced it.
Looking at the LR guidelines it states that the salesperson should ask the customer the type of mileage they will undertake before deciding what different fuel type car to buy. In the financial sector if options were not recorded there would be a successful claim for miss selling. I was not advised of the issue of oil dilution and short journeys , strange how LR can get away with it. Also they keep claiming it is not mechanical problem but blaming your driving journeys. Another way of passing the buck. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
I’m not a tools man anymore (age) so I bought the oil and just took it to a local garage and they changed the oil for twenty quid. I didn’t bother with filter. Geoff |
