Home > Technical (L322) > Fuel Burning Heater Retrofit
Page 5 of 5 <12345
RR_05_US
Germany
yep, Thermo top C
OE number is 65847E
picture attached
This should be the correct unit for my MY2005.
Post #621572 27th Jan 2022 5:26pm
RR_05_US
Germany
Update!
I could fix my FAULTMATE so I can write setting back to the instrument cluster. I enabled the park heater but still can't use it.
Here what I did already.
Instrument Cluster:
Park heating enabled
Park ventilation enabled (was the default setting)
HEVAC
Auxiliary fuel burning heating fitted
park fuel burning heating enabled
Gateway
Auxiliary fuel burning heater fitted
But unfortunately I still can't activate the heater nor using the remote neither the touch screen...
hmm, I'm running out of ideas what to do next!?
Post #621573 27th Jan 2022 5:28pm
Chris1573
I Would ditch all the timed stuff, you can trigger a countdown timer relay connected directly to the Thermotop. I use a Sim card Garage opener. SO I just call it in the morning and it comes on for 30 mins. I have posted a thread about this a while back. L322 2007 TDV8 3.6
Post #621575 27th Jan 2022 5:39pm
RR_05_US
Germany
I don't need the timer but as far as I know the OE Webasto unit needs to communicate to the car via the K-bus anyway. Otherwise you can't even switch it on nor by a Telestart remote neither by a GSM trigger. The HEVAC model needs the connection as well to open the extra water valve and switch on the blower to heat up the cabin.
Post #621576 27th Jan 2022 5:52pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
You should now have AUX Heat and Vent appear on the screen if it has updated if not I would do a battery reset thats what I had to do before it came on the screen.
Post #621621 28th Jan 2022 12:33am
RR_05_US
Germany
the park ventilation screen was already there before I started to set up the fbh. I can program the timer and ist works as it should but without switching on the Webasto unit. When I push the "manual" button on the screen nothing happens just the button got a red surrounding to show it is switched on. it seems to be the head unit doesn't send the correct message to the K-bus. Will try to play with the settings on the weekend.
Post #621627 28th Jan 2022 8:33am
Chris1573
Do you have the remote key module in the boot ? or even the three wire plug that it would normally connect to...? L322 2007 TDV8 3.6
Post #621632 28th Jan 2022 9:25am
RR_05_US
Germany
yes, when I installed the Webasto unit I also added the remote box. When I use the remote the Faultmate shows me the Webasto unit receives the signal from the box but nothing happens.
Post #621633 28th Jan 2022 9:31am
Gsxr1250dave
I think you should start a separate thread about this as it's nothing todo with my original.
Post #621657 28th Jan 2022 12:33pm
RR_05_US
Germany
In deed it could make sense to open a new thread. Maybe I will do so when I know what to do next.
Anyways, but why you claim this thread for you as you haven't started it? Looks more you highjacked it too.
Best
Post #622196 2nd Feb 2022 11:20am
Page 5 of 5 <12345
