Home > General (L460 2022) > PHEV Specs |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
27th Jan 2022 2:21am |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 422 |
Great Phillip - 70 miles / 113km EV range - impressive! This looks good |
27th Jan 2022 7:42am |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3060 |
54 miles/90km real world range. |
27th Jan 2022 8:51am |
EdJ Member Since: 30 Jan 2015 Location: London Posts: 322 |
Thanks for the link. The more powerful hybrid is short wheel base only. Wonder why that is? That is frustrating, as I was going to go for the LWB P510e. 2024 Range Rover P550e AB |
27th Jan 2022 11:19am |
It has slightly lower (~10mm) clearance as well, and only 2500kg towing capacity. But still definitely a very capable vehicle!
27th Jan 2022 3:33pm |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 718 |
Does anyone know if this PHEV is permanent 4 wheel drive even when the battery is depleted ? I know models like the XC90 PHEV are two wheel drive without the battery so wondering if this is the same ? 2021 P400 Silicon Silver AB
27th Jan 2022 3:52pm |
2500kg is very disappointing. |
27th Jan 2022 3:53pm |
Same as the non-PHEV ones, Intelligent All-Wheel Drive similar to the Defender (so can decouple the front axle for economy). |
27th Jan 2022 3:57pm |
dentaldave Member Since: 24 Dec 2020 Location: lincolnshire Posts: 41 |
Have spec’d mine today with the 510e engine.
27th Jan 2022 6:38pm |
"Same as the non-PHEV ones, Intelligent All-Wheel Drive similar to the Defender (so can decouple the front axle for economy)."
27th Jan 2022 7:02pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 771 |
The PHEV engines are on the builder now.
27th Jan 2022 7:34pm |
The P440e performance is 0-60 in 5.7 sec / 0-100km/h in 6.0 sec - not too bad!
27th Jan 2022 7:45pm |
I assume that’s the performance with the charged battery. What will it be when the battery has discharged? MY23 D350 HSE
27th Jan 2022 7:50pm |
7 CDB Member Since: 18 Dec 2017 Location: Lincoln Posts: 134 |
Nice Going to spec ours on Sat - where did you get to on the £££ ? |
27th Jan 2022 8:48pm |
