Home > Technical (L322) > MAP sensor....caused limp mode.
Tiprat
So driving along the M62 and the car suddenly "bings" and goes into limp mode. No power, no hard shoulder (don't you just love smart motorways!) Censored
Get into the first lane, then onto a grass verge, engine off, wait 30seconds restart and powers back. Up to speed pull onto the first lane, drive to services, lucky I had my diagnostics with me, run a scan, and it shows ...
Map sensor "A".
So since I have 2 Map sensors being the V8, which is sensor A?
I shall order a new one and fit it as soon as I know which one to change
Regards
Ian. Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #621686 28th Jan 2022 7:32pm
GraemeS
Australia
A should be the on the RH bank when looking from behind the engine, not from in front. If you disconnect the electrical connector you should get a permanent fault on that sensor, then swapping the sensors left to right the fault should swap sides if the sensor is indeed the cause.
Quite possibly the sensors just need a good clean with a spray cleaner.
Post #621695 28th Jan 2022 8:44pm
Range Rover L322
I replaced mine a while ago on a 2012 4.4TDV8 (while eliminating them as a cause of something), I have 2 spares which work perfectly because there was no change whatsoever when I replaced them.
If you do need one, PM me, I would be happy to sell it for less than I have advertised them for on eBay. Not sure if they are the same design as yours though.
Post #621717 29th Jan 2022 1:10am
Tiprat
Thanks for that GraemeS it has been spray cleaned before, approx 5 months ago, previous owner warned me in advance of the issue. I shall look at it again, if memory serves me right, the thin wire was touching the plastic that runs along the side of it.
Thanks for the offer Rangerover, unfortunately they are a different design to mine, otherwise I'd have gratefully accepted your offer.
Regards. Borrowed Grey 2002 3d 204k for a year
Post #621727 29th Jan 2022 9:09am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I’m interested in one of those!
Pm coming your way… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #621734 29th Jan 2022 9:37am
