![]() | Home > General (L460 2022) > PHEV Specs |
| Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443
I observe that the PHEV cannot be specified with the Cabin Pre Heating option. If this isn't due to a technical constraint, I hope it will be added as an option soon. If so, I think that at least the Norwegian importer will include Cabin Pre Heating as a standard option, similar to the other variants. |
| Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 798
Does the cabin pre-heat off the battery when plugged in like some EV's do? MY23 D350 HSE
Seems that the P510e has "Electric cabin pre-conditioning" as standard equipment, but this is not listed on the P440e. Must be a mistake! |
| Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170
I was told that it was a weight restriction issue (so presumably you could put 23" on afterwards) PHEV can only be skinny spare wheel or aerosol can. The configurator is now up and running |
We're in the ordering pool for a P510AB SWB, but consider changing back to the P440AB model due to that the P510AB cannot be delivered with 4-zone climate (in our market at least) due to weight restrictions. Such a change would require adding the "Dynamic response pro" + "torque vectoring" options for the P440AB (which then should make that P440AB vehicle equally heavy as a P510AB?).
| Renaco Member Since: 09 Mar 2022 Location: Munich Posts: 38
80nm are a lot to miss.
| aja500 Member Since: 15 Oct 2017 Location: South East Posts: 834
Erik, if you don't, (or aren't able to) select 4 zone, doesn't 3 zone come as standard, and would 3 zone not work for you?
Yes, we have 3-zone in our current L322, but with mostly adults in the rear seats on longer journeys, we thought we should spec our new dream car (for years to come) with the nice, individual comfort options (Executive Class Comfort / hot stone seats ++). That spec doesn't fit well with the 3-zone, IMO. Ideally we would have the Power Assisted doors as well, but that option is being postponed to MY24... Now we either will have to keep the P510AB spec but with just std AB seats and 3-zone, or downgrade to the P440AB engine but keep the individual comfort hot-stone options and 4-zone. First world problems indeed! |
I fully understand Erik - We have an L405 which will be going at some point, but we've owned our L322 for 8 years now, and have no plans to ever sell it.
Still an unanswered question, Phil! I guess the 3.0 straight six engine in the P510e is identical to the engine in the P400 model. But what have they done to the I6 in the P440e then? No supercharger? Or just different tuning? Anyone knows? |
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626
P440e and P510e are just different states of tune - they're turbocharged, not twincharged like the P400 MHEV. |
| All times are GMT |
