![]() | Home > Technical (L322) > Car has AMK compressor, but Hitatchi software? |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
I had exactly the same issue, with just an infrequent fault pop up.. I did use my iid to update to AMK software though and never seen a fault since. I did speak to the previous owner who said the compressor was changed and he did get the occasional fault, but he hardly adjusted height so didn’t follow it up. So worth doing even for just piece of mind. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Thank you! Just out of curiosity, what faults did you get? |
First was suspension fault popped when I went from normal to access height then to high. Switching off and restarting normal cleared issue. Read faults on IID and if I remember correctly it showed an incorrect data fault, valve issue and pressure fault. Sorry can’t be more specific. |
Thank you!
You just have to make sure you have plenty of charge in your battery, I am pretty sure it was a relatively short reflash. You can always connect a smart charger if you are worried. |
Flashed it today, and it was a but strange. At the end it said ~ECU update aborted, but when I went back into the file it had changed it?
