![]() | Home > Technical (L322) > 2007 Supercharged Misfiring |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
Check your connections at the pcv, its an inherent weakness in the design, I resorted to wrapping them in self amalgamating tape after lots of problems with air ingress |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
David,
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
I don’t think so but that’s a good thought…
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Hi David,
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
The hissing noise is normal. They breathe heavily from the PCV on the left bank to the throttle body. Coincidentally, also a common leakage point!
Mine does it on petrol and LPG until it's warm so I'm ruling out an injector or an issue relating directly to one specific fuel.
I've put two new LR PCVs on mine now and both do the same. I even bought a very expensive LR pipe to go from the PCV to throttle body. Still makes the noise. I also fitted a rubber hose so I could restrict the flow and it made no difference to how it ran.
Sounds like we've been through the same steps! |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
David
I've leak checked mine to death. No air leaks anywhere. Can still hear the air rushing through the PCV. And interestingly, if i pinch the pipe (I'm on a rubber hose at the moment), the noise stops or slows. 05 L322 4.2SC
My old 4.2 definitely didn’t make the noise that this one makes so I’m convinced something is wrong.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
David I am at work at the moment but at home tomorrow morning I will video mine so you can hear for yourself if that helps |
Thanks Sandy. |
Oddly I had multiple misfires and an eml light today, cleared the lot and all well since, weird as its been fine for the last 6 months |
