Home > Maintenance & Mods (L322) > Handbrake Shoe Replacement Issues |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1124 |
Blimey Mike that is a mess.
12th Feb 2022 12:23pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
I’m always surprised handbrake shoes wear on cars, why should they, you only apply the handbrake when the car is stationary so how come they wear?
12th Feb 2022 12:34pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 223 |
I followed the workshop manual that says to back them off 8 clicks. I suspect the EPB bedding in procedure meant the EPB module ran out of adjustment and slipped off the end of the gear which is what is making the noise. Now I am unable to release the handbrake, either via the red loop under the cup holder or the loop in the boot. Probably not pulling hard enough but can’t pull any harder. |
12th Feb 2022 12:45pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2720 |
Ah the joys of drum brakes....
12th Feb 2022 1:03pm |
I know it doesn't help now but when I replaced mine I didn't do the reset and it holds perfect.
12th Feb 2022 1:56pm |
Just read the bedding in procedure and it looks both complicated and impractical unless you have access to a private road. 2012 TDV8 Vogue (L322) |
12th Feb 2022 2:14pm |
Wish I hadn't tried the bedding in procedure. What sort of idiot writes a process that allows the controller to wind the adjuster off the end of the shaft? |
12th Feb 2022 5:44pm |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
As you said it yourself,
13th Feb 2022 9:44am |
Despite my many years of experience with fitting various brakes to various cars this is just another reason I'm going to let a LR specialist garage do mine when they need it. 2012 TDV8 Vogue (L322) |
13th Feb 2022 10:31am |
As far as I can tell the orientation of the adjuster is for consistency rather than operation. Even turning it around the other way the spring still gets pushed up. it is the pressure from the spring on the adjuster dial that ensures that it doesn't come undone in normal operation. |
13th Feb 2022 12:26pm |
Yep, well said Mike. |
13th Feb 2022 1:05pm |
Sadly it appears my EPB module is jammed solid and refuses to release. This is going to get expensive! |
16th Feb 2022 11:16pm |
Have you got an IID tool? I know I've seen an instruction on there for the handbrake. See if you can possibly do a reset? |
16th Feb 2022 11:49pm |
I've tried all the options on the IID Tool. They all fail.
17th Feb 2022 11:30pm |
