Home > In Car Electronics (L322) > Logic 7 specifications
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
Hi, I have searched hard from this forum, Google and Facebook groups for this with no luck.
I have common issue: both front low range speakers are blown.
So hence this is so common problem, I do not want to swap them to another original ones due to poor quality. Rather I want to put there something sturdier.
The problem is I can't find any information about the specs of those speakers, so I have no clue what to choose.
Only thing I can measure are physical dimensions.
What I need to know is output power, frequency range etc.
Can anyone help?
Regards
Post #623922 16th Feb 2022 6:34pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Try Pioneer, as they used to offer complete car sets.
Post #623932 16th Feb 2022 8:44pm
kokamagi
Sorry, but this answer is by far off topic.
Post #623949 16th Feb 2022 10:40pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
It’s not though, is it. He has pointed you in the direction of a company that used to, and maybe still does, make replacements as a set. You could Google them, and if you find them you might find the specs you are looking for.
Post #623953 16th Feb 2022 11:33pm
mjdronfield
You will have to replace like for like, or fit a matched component system in to the door. There is a thread somewhere about upgrades. I get what you are asking and if I remember right the factory speakers have an ohmage rating that makes substitution have less choice. It’s also an active system with the crossovers in the DSP unit.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #623960 17th Feb 2022 12:22am
mjdronfield
https://www.fullfatrr.com/forum/topic11870.html?highlight=speaker
https://www.fullfatrr.com/forum/topic54116.html?highlight=speaker
Though I’m not sure anyone has actually replaced them with anything else. You might be the first if you do it…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #623962 17th Feb 2022 12:30am
kokamagi
Thank you for the information sir. 🙂
Sure all speakers have an impedance rating, but I can't find any firm information about that, it's not even written on the speaker. I've seen somewhere in the BMW forum, that BMW Logic 7 low range speakers are 2 ohm impedance, but then again BMW system is different.
I even wrote to Harman Kardon support and asked specs, but I don't hope much from them.
I'll search a little more and then go by gut feeling.
Cheers. 🙂
Post #623964 17th Feb 2022 1:01am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
@kokamagi, have you tried asking LR? Long shot but worth a go perhaps. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #624122 18th Feb 2022 8:26pm
LowB
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I've done some fault-finding on my system and can confirm that the bass drivers are ~2 ohm impedance. Given that all the channels are direct wired from the amplifier i.e. no passive cross-overs involved. The frequency range of any replacement speaker is largely irrelevant as the amp will only send a narrow frequency range to it anyway.
After visual inspection of the bass drivers, the most challenging part of finding a 3rd-party replacement will be matching the physical mounting I would think.
This extract from the workshop manual states the following:-
Logic7 System
The Logic7 amplifier drives 14 speakers on 5.1 surround channels; two front door mid-range, four front and rear door bass
woofers, two front and rear door tweeters on eight channels and a passive subwoofer as on the DSP system, but with two
additional surround sound speakers located in the upper tail door and a center surround speaker located in the fascia.
The Logic 7 system amplifier produces 720W of digital amplification to power the speakers.
720W sounds a lot but it doesn't state whether that is RMS or peak, or at what THD level so it's largely meaningless. But, if we humour them and do the maths then that means each channel is capable of delivering 720/11 = 65W. After looking at one of the door bass drivers the voice-coil looks like it should be capable of sinking that kind of power continuously, so provided you get something rated for at least 65W you should be fine.
BTW one of my bass drivers had fallen apart too, so I've just ordered a replacement on eBay for £25. Or you can buy a new one for £115 Whistle 2011 TDV8 4.4 Vogue SE in Galway Green with Black leather
1998 Saab 900 turbo convertible in Lime Gold with black leather
Post #624658 24th Feb 2022 8:43pm
