![]() | Home > My Range Rover > L322 td6 project and defender replacement |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Nice one |
Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54 ![]() ![]() ![]() |
Gearbox is on the cards for tomorrow. So let’s see where we are with that. |
Gearbox oil change done and it was pretty black.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
Nice job of the gearbox service! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 453 ![]() ![]() |
If there’s a fix for the HDC I’d be interested as I get a similar message on start up |
Few jobs managed over the weekend.
Todays jobs put the 18 inch wheels on that I picked up last Friday. These have about half tread left on them and a matching set of general grabber GT’s on them. All four for £150 is a bargain. Some may wonder why switch from a 20 inch wheel to an 18. Firstly I don’t like aftermarket wheels on an l322 they still look up market and I feel the wheels that came with mine were bad taste for such a vehicle. Also not knowing what brand the wheels were or the quality or the load rating I thought it’s best to go to a standard Land Rover wheel. Also this was bought as a replacement for a defender so I want lots of wheel choices and sidewall for off-road work. Plus I really like the pre facelift with the smaller wheel size.
Cleaning has commenced on the intake. It’s not perfect but certainly improved and with the egr delete fitted it won’t get that bad again. After cleaning 2 ports on the engine itself.
Just a few small jobs today. Fitted the egr delete when I did the inlet manifold so today was getting rid of the egr cooler. Most wouldn’t bother with this but after having quite a few m57 powered cars I’ve had the egr cooler fail allowing coolant in the engine where it shouldn’t be, it also allows far better access to the front of the engine especially with the viscous fan permanently removed as well.
Haven’t posted on this for a while but not much to update. Was made redundant at the end of March and as the Range Rover is a second car it hasn’t been used much. However first real task called for a tow vehicle.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 542 ![]() ![]() ![]() |
very nice mate .....keep it up |
