![]() | Home > Technical (L322) > Front camshaft seal/front main seal |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1051 ![]() ![]() |
What engine ? |
Brerfox Member Since: 22 Dec 2021 Location: Wales Posts: 17 ![]() ![]() ![]() |
Hi sorry its the tdv8 4.4 2012 |
so I'm stuck, can't get the crankshaft pulley bolt off, even borrowed a impact driver with a 1000nm bolt breaker is there some sort of holding tool for the pulley or is a case of taking out the starter? this is for the tdv8 4.4 2012 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
Could it have a left hand thread? |
It has a thread which undoes by turning anticlockwise. I have bought a new bolt to go back in |
Can you get a strap wrench to go around the pulley and wedge it against something solid? |
I have a nearby tool station, ill have a look |
so wasn't to bad used a stump puller to fix the pulley
So I thought I had fixed this as no more oil leak… until Thursday when I noticed some oil on the drive, so took under trays of to find oil is pouring out from behind crank seal |
Do you have to stake the seal in place? Does it recommend using an adhesive?
Hi the seal comes with what I would call an introducer? Which goes over the front of the crank shaft and then I use a socket which probably touches the out side edge of the seal give or take a couple of mm and then it taps in using a rubber mallet there are grooves on the outside edge of the seal and ridges on the inside of the of the engine seal well I assume they pair up? The seal ends up flush with engine. |
Craggers Member Since: 01 Sep 2025 Location: Worcestershire Posts: 6 ![]() ![]() |
Having the same issue of the seal getting blown out over again, did you ever get to the bottom of this? |
I replaced the oil pump and sealed the oil seal in job done |
Thankyou for replying, what did you use to seal it in? |
