![]() | Home > Technical (L405) > Fumes in cabin when warm & stopped/going slowly - SDV8 |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Have you checked the intercooler in the `V` check for oil in the expansion cooling tank? It`s a known fault? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721 ![]() ![]() ![]() |
It’s the vent pipe for fbh, it vents below the gear shifter, very common . Mine is the same , very bad smell when it’s cold and no wind to blow it away . |
thomsonaj Member Since: 03 Mar 2022 Location: Scotland Posts: 5 ![]() ![]() ![]() |
Thanks both - appreciate the replies.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
My money is on the oil cooler |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
are you sure it is diesel fumes and not burning oil fumes?
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
There are a couple of O rings that get brittle on the turbo feed pipes that can allow oil to leak out onto the bell housing.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
I agree, either oil cooler or o rings. Have a look in the V to see if you can see oil. Kev
Thanks very much all - took her into the garage this morning so will see what they come back with. Such a wealth of knowledge on here, want to reiterate thanks for suggestions so far.
ivo_markov Member Since: 21 Mar 2022 Location: Brussels Posts: 19 ![]() ![]() ![]() |
Got this done last week, 600Euro job at the main dealer. It was hot oil smell, tried changing cabin filter at first too.
Closing the loop on this one - smell was a fractured ARB header tank (the one that's a dark colour on the nearside front of the engine bay, makes it impossible to see fluid volume...) which was leaking fluid onto the manifold when under pressure.
JakeyKev Member Since: 07 Jul 2023 Location: Scotland Posts: 5 ![]() ![]() |
Hi ThomsonAJ,
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758 ![]() ![]() |
JakeyKev,
Ah cool, thanks MarianaWestminster.
