Home > Technical (L405) > Fumes in cabin when warm & stopped/going slowly - SDV8
thomsonaj
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
First up, thanks to all the contributors on this forum, such a wealth of knowledge and experience, very much appreciated!.
Just picked up a 2013 SDV8 AB, overall very happy with it but noticed pretty pungent fumes in the cabin when in traffic or going slowly. It’s most apparent when arriving home as I have a tight drive that faces upwards = going slowly and under load, cabin is immediately inundated with sickly diesel fumes. Nothing at all when cold and doesn’t seem to be ambient temperature related. I fitted a Mann FP cabin filter with no change in results. Recirc button also doesn’t affect it and it happens regardless of A/C or fan being on.
I’ve done some searching and have read a handful of threads which mention a couple of things I’ve ticked off as ‘likely not’:
- FBH - doesn’t happen when cold, which I believe is a symptom of the FBH exhaust issue.
- Hose leak - doesn’t seem down on power, no smoke when hot or cold and no codes/error lights. Averaging 35-37 mpg over the past 400 miles which seems in line with expectations.
As I’ve only just bought it, it’s going back to the dealer tomorrow to have it looked at (along with an oil leak somewhere on the near side that’s making its way to the front side step bracket and dripping onto the drive and an odd hissing noise it’s making when turning right under load)
Anyone experienced anything similar? Thanks in advance.
Post #625636 7th Mar 2022 7:59pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Have you checked the intercooler in the `V` check for oil in the expansion cooling tank? It`s a known fault?
Post #625643 7th Mar 2022 8:36pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
It’s the vent pipe for fbh, it vents below the gear shifter, very common . Mine is the same , very bad smell when it’s cold and no wind to blow it away .
Post #625645 7th Mar 2022 8:44pm
thomsonaj
Thanks both - appreciate the replies.
Mr Tee - opposite of the usual FBH symptoms, it’s happening when warm for me. Had a variety of ambient temps over the past week and same result = fine when engine cold but pungent when warmed up. Especially on the back of a ‘run’ i.e. in traffic after leaving motorway.
Tinman - interesting, will check tomorrow. I had a sift through the history file, it was in last March for an oil leak from turbo feed pipe and observed oil in the coolant so may well be related. Apparently the oil cooler to EGR was leaking which was causing coolant contamination. According to the file, the coolant rail was replaced as it was observed to be brittle.
Will report back with dealer’s findings.
Post #625648 7th Mar 2022 9:26pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
My money is on the oil cooler Thumbs Up
Post #625650 7th Mar 2022 9:27pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
are you sure it is diesel fumes and not burning oil fumes?
if it is burning oil then oil cooler is to blame as this was my experience on my TDV8.
there are some posts on here about the oil seals that fail too all to do with the oil cooler. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #625666 8th Mar 2022 9:04am
mpirie
There are a couple of O rings that get brittle on the turbo feed pipes that can allow oil to leak out onto the bell housing.
Then there's the oil cooler itself leaking into the Vee where it sits and gets hot.
Best to check both and they're in the same vicinity on top of the engine.
Mike
Post #625681 8th Mar 2022 1:51pm
knwatkins
I agree, either oil cooler or o rings. Have a look in the V to see if you can see oil. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #625697 8th Mar 2022 3:44pm
thomsonaj
Thanks very much all - took her into the garage this morning so will see what they come back with. Such a wealth of knowledge on here, want to reiterate thanks for suggestions so far.
To comment on the actual smell - could well be oil, it’s a sort of sticky almost kerosine-y smell which I’d put down to diesel but thinking about it is far more likely to be burning oil.
The car’s being looked at tomorrow so will update with their findings. As for the hissing/vibration noise under load, pretty sure that is the ARB pipes buzzing on a bit of the side steps when turning rights, that’s being diagnosed too.
Not sure on the protocol of naming garages on here but the dealer (non LR but main brand) has been great on after-sales service.
Post #625713 8th Mar 2022 6:03pm
ivo_markov
Belgium 2016 Range Rover Autobiography SDV8 Indus Silver
Got this done last week, 600Euro job at the main dealer. It was hot oil smell, tried changing cabin filter at first too.
Whole bunch of gaskets and o-rings needed changing, not the oil cooler itself
edit: All these were changed -
LR113004
LR022903
LR023100
LR022772
LR022777
LR023022
LR022775
LR023021
LR124504
LR023145
Coolant and oil needed changing too
Post #626641 21st Mar 2022 7:12pm
thomsonaj
Closing the loop on this one - smell was a fractured ARB header tank (the one that's a dark colour on the nearside front of the engine bay, makes it impossible to see fluid volume...) which was leaking fluid onto the manifold when under pressure.
Dealer fitted new tank and smell has gone and hissing/rattling has also been fixed by insulating the pipes next to deployable steps.
Thanks all for the input Very Happy
Post #627700 4th Apr 2022 11:02am
JakeyKev
Hi ThomsonAJ,
I've got the exact same problem with my TDV6. Smell of diesel or exhaust fumes inside cabin when it's warm outside so its not the FBH.
What is the ARB Header Tank that that you had replaced? I've been trying to think what ARB stands for and can't 😀.
Cheers
Post #668560 7th Jul 2023 9:27am
MarianaWestminster
JakeyKev,
The OP is referring to the reservoir for the dynamic response system (active anti roll bars)
It contains the hydraulic fluid utilised by the system.
As you have a V6 you do not have this system as it was only fitted to SDV8 and supercharged models.
Hope this helps!
Post #668565 7th Jul 2023 10:04am
JakeyKev
Ah cool, thanks MarianaWestminster.
I'll crack the bonnet open this weekend and have a poke around see if I can spot any leaks.
Cheers
Post #668570 7th Jul 2023 11:14am
