![]() | Home > My Range Rover > Back with another Supercharged |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3846 ![]() ![]() ![]() |
David,
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3309 ![]() ![]() ![]() |
Thanks Mike, the calipers were actually pretty easy to do |
Was thinking about the subframe bushes today as they’re huge and are an incredibly tight fit into the subframe. After a big of Googling it turns out they’re the same bushes as in the rear subframe on the BMW X5.
Changed my mind again… Several reasons for doing so…
Been a busy evening tonight…
Managed to get a few more jobs done today.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
David, looking at your front brake callipers... Do you have own any Paint Protection Film? Cut a piece to fit the front panel of your caliper where you have fitted the BREMBO decal and voila your decal will never peel |
That’s a great idea! Thanks Craig!
You May be able to pan in on mine and see the PPF?
Is it easy enough to apply? I’ve seen video’s online that suggests soapy water and a rubber blade or similar to spread it smooth. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Make sure to only buy 3M stuff David... Tis the best ![]() |
Yes, very easy... Spray bottle with clean water, soak the area, apply and squeegy out... ![]() |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
hats off Dave fantastic job |
