![]() | Home > Technical (L322) > Advice on egr delete please, 4.4tdv8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
Who did it for you? May I ask why you had it done? Were you experiencing dpf issues? I'm intrigued if the dpf is still in the exhaust, will it clog up given its physical construction? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7977 ![]() ![]() ![]() |
A fair amount of discussion on the subject here;
GTTURBO87UK Member Since: 16 Mar 2022 Location: Reading Posts: 27 ![]() ![]() ![]() |
Dpf is gutted out and deleted so no dpf, I just wondered if I have to physically block the egr or unplug it. I had a blocked dpf so thought I would fix it permanently, thought I would do egr at same time |
Ah, dunno then. I wouldn’t suppose it mattered if you unplugged them then. Others will be along soon that are more knowledgeable on the subject…. But imagine if you unplug them and it throws an error… plug them back in….
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 ![]() ![]() ![]() |
ask the people who did the ecu ???? I am sure they know 2012 Black 4.4 TDV8
I blanked the egr but intermittently am getting limp mode and fault code p042d-00. To mute knowledge it’s the temperature sensor that goes on the dpf. Surely they should have deleted that sensor when doing the rest? I have emailed them about it just waiting for a reply. Very frustrating as I thought this would permanently fix a problem |
The egr doesn’t need blanking I found out you just delete it on the map |
Who gutted your dpf and remapped the ecu? Interested how it pans out....
I gutted it and welded it back up, I found a guy on the internet who done the map on the ecu. Now I’m averaging 30mpg and great performance too. |
Gotcha!
