Home > Maintenance & Mods (L322) > 36mm Viscous fan spanner |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 444 |
It’s a bit of a lottery to be honest, some come off easy while others seem to have been tightened up by the Incredible Hulk.
27th Mar 2022 11:18am |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 927 |
Laser one is OK but obviously you risk a chance of damaging items if you needed to give it a thump to break the seal.
27th Mar 2022 11:27am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
I used one from Island 4X4, Still had to give a couple of good thumps before it shifted though. |
27th Mar 2022 11:31am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1128 |
Thanks guys. |
27th Mar 2022 4:37pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 73 |
This is an easy one.
28th Mar 2022 5:38am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
£14 Halfords. Spray the nut first, drink a cup of tea, spray again. Put spanner on, and with a medium hammer, and a thick gloved right hand, hit the spanner to the right, and catch the spanner with the right hand. About 4 inches away. Takes a few. Hits. |
28th Mar 2022 6:52pm |
Thanks all for the useful information. |
28th Mar 2022 7:46pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I ended up using a cold chisel to get it loose Got - 2017 SDV8 Autobiography in Loire Blue
28th Mar 2022 8:35pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Large adjustable spanner and an £8 ebay 36mm special . Clouted the adjustable once and the nut undid been on for 20 years and came off no problem. Viscous fan and shroud binned |
7th Apr 2022 11:15am |
I bought a cheap 36mm open ended straight shaft spanner, put an extension tube on and it cracked off quite easy. Was expecting to struggle but it is quite a new fan so I'm happy. |
7th Apr 2022 11:19am |
if you use a chisel, you are stressing the bearing on the water pump, with every hit...and that can make the seal fail, ...either will cause the water pump to leak/wear/fail. |
10th Apr 2022 9:03pm |
There was no other way to get it loose and more 2 years down the line, no water pump issues Got - 2017 SDV8 Autobiography in Loire Blue
11th Apr 2022 5:48am |
