|  | Home > Technical (L322) > Range Rover 4.4L V8 NO START |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      |
 Car will NOT start.  I took the dash apart cleaned all the fuses inside the central junction box, checked if they were grounded. Did the same in the engine box and the driver side tailgate fuse panel. Then I get 8 faults and was able to clear them ALL except U126, car started up and back up camera worked and transmission shifted normal. Today car will not start and I can not clear these two faults with code reader.
|  27th Mar 2022 2:29am |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      | the dealer jumped the TCM by wiring a red wire in the engine fuse box that If left plugged it caused the battery to drain, they say the wiring that goes to the transmission was bad but I was not clear and did not expect them to Hotwire to get the car to start since the transmission wouldn't shift correctly. I do know why SAS has lost communication. The dealer ran a red wire from the SAS to the central junction fuse box, when checking  fuses I u plugged it and plugged it back in...not sure I put it in the right number fuse slot. Would you happen to know which fuse slot this red wire should go back in? I think it was a blank slot around fuse number 10ish or so??? I will check when I get home and reply back on the specifics.
|  27th Mar 2022 6:29am |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      | What other faults would be High speed Can bus related, because I do have a faulty electronic parking brake. | ||
|  27th Mar 2022 6:36am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777    | If you're not seeing lots of other lost communication faults then there won't be a general canbus fault.
|  27th Mar 2022 8:01am |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      | The one I see the most often is the TCM. | ||
|  27th Mar 2022 8:56am |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      | Im not sure why the dealer installed a red wire from the steering angle harness to the central junction fuse box, but i put it back in fuse 18 like it was before. Now the SAS fault is gone. I still can not clear lost communication with TCM and my battery voltage is coming up at 12.26 volts so I put it on charge overnight.
|  28th Mar 2022 5:15am |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      | I uploaded the faults I received all day to my photo gallery. Please take a look when you get the chance. | ||
|  28th Mar 2022 5:17am |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      | Does anyone know what fuse/fuses powerup the transmission control module for my vehicle?
|  28th Mar 2022 5:24am |
| c2thez Member Since: 10 Aug 2019 Location: Houston Posts: 10      | Looking for a wiring diagram for transmission  | ||
|  28th Mar 2022 5:38am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777    | I only have the wiring diagram for MY10-12 which could easily be different, but mine's SAS's power is sourced from fuse 5 in the passenger fuse panel which gets its power from the ignition relay.
|  28th Mar 2022 7:53am |
| Posting Rules
