![]() | Home > Technical (L322) > Restricted Performance Warning & DPF Full amber light |
Crusty21 Member Since: 29 Mar 2022 Location: Cheshire Posts: 48 ![]() ![]() ![]() |
Thanks Kevin
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1343 ![]() ![]() ![]() |
Yes mate, you have to buy the whole hose. I was lucky and had mine changed under warranty. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3347 ![]() ![]() ![]() |
Are you sure the seal is leaking? I had mine off and just cleaned the seal and the surface on the TB and it seemed fine and the seal was intact with no apparent wear or damage. I'm sure some PTFE would be a reasonable fix as well. You would assume it would be a flexible part secured by a jubilee clip like the rest of the connectors in the system unless it's designed blow off in some over boost situation? 2012 TDV8 Vogue (L322) |
Mine was more oily on the end of the hose than your photo, but mine is bone dry now.
The connection to the throttle body was very loose and the retaining clip pretty much dropped out. There was a lot of oily residue in the hose and on the inside and outside of the plastic elbow connector (don't actually know what it's called |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
From tour earlier post I reckon you have been doing too many short journeys. The 4.4 tdv8 needs to get nice and hot on a long run. Short blasts will soon fill a DPF. Short journeys are a killer for a 4.4 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
HEEEEEEEEEELP! |
Not sure if revving it to 3krpm is going to help and it may actually prevent the proper regen process taking place. Until you get the codes read it's not helpful to speculate. 2012 TDV8 Vogue (L322) |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3265 ![]() ![]() ![]() |
I suspect you have a leak, or possibly the Inlet manifold is cracked. It's c. £1600 to replace one. They were known to be too flimsy to withstand the pressure of 2 turbos and have since been beefed up.
I doubt very much if a small leak will cause this. Likely a run up the M-Way is just doing a passive regen and some other system or sensor fault is stopping it going into an active regen and this will only be revealed when you get it scanned. IMO and IME L322 ownership is an unrealistic proposition without a GAP IID tool. 2012 TDV8 Vogue (L322) |
Henshall Engineering will find it and fix it quicker than you think. Family friend had same issue. James Henshall reset everything (don't ask me how, I don't know) and its now good as gold.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
Regens work best between 40-60mph in Drive. Ideally using Cruise Control.
An intake leak big enough to cause excess soot via overfueling would throw an engine fault which is easier to identify with a fault scan than a high pressure smoke test IMO. Getting fault scan is the first and main priority. 2012 TDV8 Vogue (L322) |
