Home > Maintenance & Mods (L322) > Oil Cooler Change - When it started so well
davethomas83
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Hey Team,
So started process of changing the oil cooler today, all going well stripping down the engine, then come to the last bolt to undo, and the buggar is rounded, and can i get enough purchase with anything to get it out, can i jeff !! Censored
Its this one ( picture isnt from mine, its from the awesome pictures on the wiki )
Im assuming its rounded on the top because someone previously has tightend this up to within an inch of its life. I havent got this far to put it all back together, so looking for some suggestions about how to get this out. Ive basically ran out of wd40 ive sprayed so much as it, ive tried various pliers but just can get enough purchase and the position of it is a royal pain.
Please bestow upon you me your must genius solutions.
Post #627538 1st Apr 2022 3:44pm
mpirie
If you don't have the right torx socket......mole grips?
Or hammer a small socket onto the post and remove?
Or two nuts tightened together on the thread and the right spanner? Try and undo the lower nut while keeping the upper nut from moving.
Mike
Post #627540 1st Apr 2022 3:50pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Yeap, that's what I would do; two nuts and may be a bit of heat with a propane torch!?
Post #627541 1st Apr 2022 3:53pm
davethomas83
Cheers Gents - think I might be a little scared to get heat in there due to the pipes, put 2 nuts now that’s a sensible idea!
I did try some mole grips, but the ones I have are on the large side so couldn’t really get the angle for maximum effect.
Dig around in the garage now for some suitable nuts ( I’ll probably have 1 based on how my days gone so far 🙄 )
Post #627546 1st Apr 2022 4:09pm
davethomas83
So far, I at least have the nuts that fit so good start.
Just need to brew coffee before I can brave the cold outside 😂
Post #627548 1st Apr 2022 4:37pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Two nuts locked is the way to go, for the future forget WD40 it's rubbish for anything other than cleaning, use plus gas for freeing off fastenings, available by the gallon on Amazon with a pump spray, much better. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #627573 2nd Apr 2022 3:58am
Fox889
A slightly smaller long reach socket gently hammered into place? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #627578 2nd Apr 2022 8:13am
A 9mm 16 sided long reach socket knocks on nicely from experience… Do at least 2 of these a month and many of them are stuck!
Craig Thumbs Up
Post #627585 2nd Apr 2022 8:29am
davethomas83
Thanks for all the suggestions guys - had a quick look yesterday at the 2 nut option, but muggins over here has caused a bit of damage to the tread trying to get it out with pliers. Only tried for a couple of mins as the pull of the pub won out the day.
Going to tackle that again today, going to get some Plus Gas before i start, hopefully i can convince the nuts onto the tread and it will be simple enough.
Ill probably need to get a replacement bolt also, it seems the top has worn away, so not only is it rounded, but there is only the smallest part of the actual hex bit left, anyone now the part number / type of bolt it is ?
Post #627591 2nd Apr 2022 9:51am
GraemeS
Australia
LR023027 appears to be the stud.
Post #627593 2nd Apr 2022 10:20am
davethomas83
Thumbs Up thanks Graeme
Post #627594 2nd Apr 2022 10:43am
davethomas83
Success !!
In the end used the plus Gas and then smashed a 5mm hex over the top ! Thanks for suggestions all.
Now onto the actually job at hand, changing this puppy
Post #627598 2nd Apr 2022 2:53pm
davethomas83
So with one source of potential oil leaks resolved - still have far too much oil coming out to consider it just residual.
Poking around the front of the engined whilst trying to sort 2nd turbo actuator ( Jesus the list just goes on ), I noticed this
Should the hole in the middle of the picture have some sort of bolt in it ?
It’s right under the throttle body so can’t see it when all plugged in, but as oil goes everywhere and this is right above the belts, I’m hoping someone can confirm my theory ( plus advise on a part number if my luck is really in )
Thanks
Post #627967 6th Apr 2022 5:47pm
davethomas83
After watching some YouTube videos ( i couldnt find this detailed on any engine diagram i cold find ), i think this must be mabe an engine mount point, as nobody has anything in this.
The search for the leak continues
Post #628007 7th Apr 2022 8:43am
