Home > Technical (L405) > Plastic Enginer Cover Paint
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Anybody else find that the silver stripes on your LR engine cover flake off when wiped clean? I've already had mine replaced under warranty and I had hoped they changed the process but the paint has just flaked off again! 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #547531 18th Mar 2020 7:21pm
Gremlin500
Post #626070 13th Mar 2022 1:45pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
(Gremlin500)(Where can you get those 4 rubber grommets under the cover that the 4 ball-and-socket pegs from the engine fit into?)
Ford Focus MK2 04-11 1434444 Engine Cover Trim Rubber Mountings Bush Cushion
These are the type I used for the rear back ones in the engine cover , fitted a treat Thumbs Up think I had to slightly trim them a bit to fit
the front ones are different Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #626110 13th Mar 2022 10:19pm
Gremlin500
Post #626113 13th Mar 2022 11:27pm
aljo
no special tools needed just a stanley knife Thumbs Up
I seem to remember the front ones are a bigger size (although I may be wrong) I had the 2 missing at the rear of the cover Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #626114 13th Mar 2022 11:34pm
Gremlin500
………… V6 Vogue - “Less is More” - less to go wrong!
Post #627958 6th Apr 2022 4:40pm
Kot
Just keep the bonnet closed Rolling with laughter Rolling with laughter
No one will know Rolling with laughter Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #627959 6th Apr 2022 4:45pm
aljo
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #627987 6th Apr 2022 8:36pm
Gremlin500
………. V6 Vogue - “Less is More” - less to go wrong!
Post #627999 6th Apr 2022 10:55pm
