![]() | Home > Technical (L322) > Please carry a decent jack |
| Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342
those standard jacks have plenty of nicknames, none of them good!
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
Mercedes Sprinter bottle Jack is the way to go.
| Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122
Lesson identified. Have sent Ben a message about a Sprinter jack. Thanks chaps |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
I carry an old style LR jack with the 2 "horns". Works a treat under the lower suspension arms all round. 2 pumps and wheel is clear.
| James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303
Me too - on the D4 it went straight in the recycling. I have kept the FFRR one in the boot just for neatness/resale etc. but carry a suitably rated bottle jack with adequate 4x4 lift which worked well even off-road with D4.
| philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527
Are bottle jacks as good as a trolley jack for swapping wheels/changing brakes at home on a flat surface? (With axle stands of course). |
| oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397
just reading this post ok the jack that is with the car for the money you spend is very sad . but i think that if you would of used the wheel chocks that are in the boot this would have not come of the jack . i would have put one in front of the rear passengers wheel and the second one at the back of the passengers rear wheel or tyre if you like . i no it is in park and hand brake on but it can still rock front and back just saying . new vehicle purchase
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3402
Bottle jack for the boot, trolley jack for the garage - OE jack for the bin.
trolley jacks have a far better foot plate more stable than the bottle ref phillip 1972 post my return comment new vehicle purchase
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
Don't usually stow a trolley jack in the boot though🤔 Previous cars:
Bottle jacks are and were only ever for emergency use in changing a wheel by the roadside. They rely on having 3 wheels on the ground to stop any lateral movement of the car when it’s lifted on a jacking point as they have no inherent lateral stability. Trolly jacks are a different tool altogether for garage use. The ones I would use for a vehicle the size of an L322 would be too heavy to lift into the boot even if there was the space. The small trolly jacks I’ve seen recommended here sometimes are little better than a bottle jack in terms of stability on a vehicle this size and weight esp as they will need to be fully extended to lift an L322 and therefore at maximum instability. Also they need a flat hard and smooth surface like a concrete floor to work properly as the wheels need to creep to maintain stability as the vehicle is lifted. I’d place much more emphasis on getting a large and substantial pair of axle stands than a jack as at least you can carry one in the car for emergency use. 2012 TDV8 Vogue (L322) |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Yes and as mentioned above Axlx stands are essential in my opinion even when changing a wheel.
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
I've only had to use my standard jack once for a puncture on a front wheel. The ground was flat and I raised the suspension first. Once the wheel is off the ground I always test the stability of the jack by gently nudging the car and then really giving it a good sideways push.
i was replying to phillip 1972 post is a trolley jack better which i said yes it is . i never said anything about putting one in the boot this is for appj62 comment that he made new vehicle purchase
| All times are GMT |
