Home > Technical (L322) > Please carry a decent jack
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
A summary lesson in crap jacks.
I had a double puncture on the 2 nearside wheels tonight which was rotten luck. Anyway while I was waiting for the truck to take me home I thought I would do something useful and change the front for the spare.
Off with the wheel nuts and under with the jack. Level tarmac ground in a lay by so should be a breeze I hear you think. When I am at home I always use my trolley jack but didn't have it in the car today.
Anyhow, round and round it goes until the wheel is off the floor and I stop my only physical exercise for the day. Just as I slide the wheel off the hub, the jack gives way and the car lurches towards me. I'm not in a happy place as this happens but, luckily, the brake disc comes to rest on the inside of the alloy wheel. No damage done. I'm experienced enough to keep everything clear when jacking and was only using the jack provided in the emergency situation I found myself in as I didn't have my trusty Costco trolley jack. Anyway the truck turned up (after a couple of hours.....) and we get the trolley jack under the car and hey presto, easy peasy.
The jack had just buckled under the weight of the car. I suppose I might have over extended it but I don't think so. The tyre was quite flat and the bottom of it only an inch or 2 off the ground.
On the hunt for something lightweight and/or and robust enough to replace it now. I hope this helps someone who might not be as lucky as I was this evening.
Post #628415 11th Apr 2022 9:50pm
Range Rover L322
those standard jacks have plenty of nicknames, none of them good!
have a read of this...
https://www.fullfatrr.com/forum/topic14177...ottle+jack
Beautiful car by the way... looks great in stornaway !
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #628416 11th Apr 2022 9:54pm
mjdronfield
Mercedes Sprinter bottle Jack is the way to go.
The factory one is useless… as you have now found out.
Least you are ok.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #628417 11th Apr 2022 9:54pm
Goldstar
Lesson identified. Have sent Ben a message about a Sprinter jack. Thanks chaps
Post #628418 11th Apr 2022 9:56pm
DrRob
I carry an old style LR jack with the 2 "horns". Works a treat under the lower suspension arms all round. 2 pumps and wheel is clear.
I threw the LR scissor jack "Widow Maker" on Day 1 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #628423 12th Apr 2022 8:47am
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Me too - on the D4 it went straight in the recycling. I have kept the FFRR one in the boot just for neatness/resale etc. but carry a suitably rated bottle jack with adequate 4x4 lift which worked well even off-road with D4.
How manufacturers are allowed to provide those pressed-steel jacks is beyond me in an age where we benefit from so much safety regulation in every other field of lifting and pulling, etc.
I am glad that you managed to escape the situation, good of you to share your experiences for the education of others. FFRR SDV8 Autobiography
Post #628424 12th Apr 2022 8:57am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Are bottle jacks as good as a trolley jack for swapping wheels/changing brakes at home on a flat surface? (With axle stands of course).
Post #628431 12th Apr 2022 9:55am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
just reading this post ok the jack that is with the car for the money you spend is very sad . but i think that if you would of used the wheel chocks that are in the boot this would have not come of the jack . i would have put one in front of the rear passengers wheel and the second one at the back of the passengers rear wheel or tyre if you like . i no it is in park and hand brake on but it can still rock front and back just saying . new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #628437 12th Apr 2022 10:20am
JayGee
Bottle jack for the boot, trolley jack for the garage - OE jack for the bin.
Chocking the diagonally opposite wheel is a must. There is so much suspension travel that to get a wheel off the ground introduces a substantial force along the driving axis. 2012 TDV8 Vogue (L322)
Post #628458 12th Apr 2022 2:47pm
oggy
trolley jacks have a far better foot plate more stable than the bottle ref phillip 1972 post my return comment new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #628469 12th Apr 2022 5:08pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Don't usually stow a trolley jack in the boot though🤔 Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #628498 12th Apr 2022 8:36pm
JayGee
Bottle jacks are and were only ever for emergency use in changing a wheel by the roadside. They rely on having 3 wheels on the ground to stop any lateral movement of the car when it’s lifted on a jacking point as they have no inherent lateral stability. Trolly jacks are a different tool altogether for garage use. The ones I would use for a vehicle the size of an L322 would be too heavy to lift into the boot even if there was the space. The small trolly jacks I’ve seen recommended here sometimes are little better than a bottle jack in terms of stability on a vehicle this size and weight esp as they will need to be fully extended to lift an L322 and therefore at maximum instability. Also they need a flat hard and smooth surface like a concrete floor to work properly as the wheels need to creep to maintain stability as the vehicle is lifted. I’d place much more emphasis on getting a large and substantial pair of axle stands than a jack as at least you can carry one in the car for emergency use. 2012 TDV8 Vogue (L322)
Post #628521 13th Apr 2022 4:51am
GGDR
Yes and as mentioned above Axlx stands are essential in my opinion even when changing a wheel.
Also leave a slightly door open when jacking as this will prevent any self adjustment of the air suspension. Cheers, Greg
Post #628523 13th Apr 2022 5:45am
kevinp
I've only had to use my standard jack once for a puncture on a front wheel. The ground was flat and I raised the suspension first. Once the wheel is off the ground I always test the stability of the jack by gently nudging the car and then really giving it a good sideways push.
I must say the jack felt very secure and stable. Like previous comments, a bottle jack has as much footprint as the scissor jack and if the car can move I think both have a chance of bending or toppling.
Post #628525 13th Apr 2022 6:09am
oggy
i was replying to phillip 1972 post is a trolley jack better which i said yes it is . i never said anything about putting one in the boot this is for appj62 comment that he made new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #628543 13th Apr 2022 9:36am
