Home > In Car Electronics (L322) > Apple CarPlay radio unit
Page 5 of 5 <12345
supershuttle
My sat Nav packed up and my new iPad is Wi-Fi only so no gps. So I’ve just been using Waze on my phone, spoken instructions come into car system as phone calls. As well as real time it also made me realise that for most of my journeys I don’t actually need a sat Nav at all Geoff
Post #616579 16th Dec 2021 10:15am
..but its handy to have though...
cant wait till next year for my euro trip [if its allowed]..i have till now used a cheap chinese nav using igo primo for maps and directions so using waze or google maps will be interesting..
@Mike...the code is 8888.. Wink ... - .- -.
Post #616598 16th Dec 2021 11:27am
Baltic Blue
I have moved home to an area where I am new to and have used satnav more this past year than any previous, mainly to find shops , jab venues, local 4x4 indi….etc…etc.
I was mainly using Apple maps on my iPad, but now over the moon with Apple CarPlay on the larger ,brighter Intellidash screenI have fitted.
Mike.
Stan
Sorry if I mislead you.
I have scoured the booklet and can’t even find where I got 0000 from.
I assume it is just to lock the screen ??, but not really needed because it goes off when you unplug your phone .
Post #616609 16th Dec 2021 12:41pm
the 4 zeros are for the BT connection Mike...the 8888 password code is for a config screen which doesn't do anything different to the normal settings screen. ... - .- -.
Post #616613 16th Dec 2021 12:51pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
For those who have the intellidash, could you please help with the following:
- how big is the whole unit if placed directly over the existing screen? Does if interfere with the buttons and dial?
I’m wondering if a simple bracket could be fashioned that would allow the intellidash screen to cover the stock screen for most use, but could be rotated up along the top edge to access the stock screen when needed. Even better would be a 2-position bracket that allowed the unit to cover the screen or sit above it whilst using the same dash fixing point? Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #628497 12th Apr 2022 9:34pm
the size is approx 178x109x18mm..
any kind of mount can be fettled..have a look at the threads relating to this unit. ... - .- -.
Post #628524 13th Apr 2022 6:54am
Baltic Blue
Apple CarPlay is so much better than the original Nav system, so this relatively cheap option is a good easy way to update the car.
My advice would be to buy one and then work on a way to mount it that best suits you.
Post #628527 13th Apr 2022 8:13am
Baltic Blue
Here is a photo showing the Intellidash unit sat directly in front of the original fitted screen.
It fits well, still giving access to all the knobs/ switches.
I am going to stick it to the original screen using a couple of double sided Velcro patches just to see how it goes.
Mike.
I have now made a very simple “L” shaped bracket, Velcroed to the back of it that pushes in to the gap under the dashtop and can’t be seen, but the whole thing can be removed in seconds if I want to see original screen.
Mike.
Post #628766 16th Apr 2022 9:46am
Baltic Blue
Mike.
The screen is so much brighter and crystal clear compared to the original, even in bright sunlight. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #628781 16th Apr 2022 1:17pm
supershuttle
I just bought one of these second screen things from China (original SatNav packed up) it only cost me less than a hundred quid and it works fine with my iPhone (using Waze) however mounting the screen in my 405 is actually presenting the biggest challenge as the unit is slightly thicker than a "normal" tablet so a claw type mount doesn't work. I got a magnetic one but the bit that sticks to the screen keeps coming unstuck anyone got any ideas?
As I only use the Nav it doesn't interfere with the normal workings of the car , heated seats, massage, radio etc. The phone works OK but how it handles calls is a bit of a mystery and when I disconnected the screen (it actually came unstuck) the phone kept on with the Waze directions by ringing me up. Geoff
Post #629008 18th Apr 2022 8:53pm
Baltic Blue
Stan’s your man for L405 questions, sorry far too modern for me. Rolling with laughter
Post #629046 19th Apr 2022 8:56am
supershuttle
Well I stuck with it, bought 3 different types of mount - but none produced the effect I wanted so I just modified the redundant Brodit mount I used for my iPhone (which now charges wirelessly) - perfect, although I do need some shorter wires. Very Happy Very Happy I just realised the thread is for old cars not L405s (or 460s come to that) Shocked Shocked
 Geoff
Post #629112 19th Apr 2022 5:51pm
Baltic Blue
You bagged a bargain at less than £100 Geoff Thumbs Up
Cheers
Post #629183 20th Apr 2022 8:50am
supershuttle
https://www.aliexpress.com/item/1005003814...1802UkrVNz
Obviously it takes a few weeks to arrive but it seems to work OK. Instruction manual leaves a bit to be desired but of course thats what you get when you buy from China. Very Happy.
I connected Wireless to phone, and used power and mic leads (not sure I need to do this). But it navigated me from North Yorkshire to Lancashire using Waze while I listened to the original car radio, whilst connected the directions come from the unit. Geoff
Post #629224 20th Apr 2022 2:20pm
Page 5 of 5 <12345
