Home > Technical (L322) > Strange noise after shutdown 2011 TDV8 4.4 - EGR fault? |
pablo Member Since: 03 Oct 2021 Location: kildare Posts: 20 |
Hi paul here in ireland,im wondering did you get to the bottom of the fault as it happens my 2012 4.4 tdv8 as well,plus i have major oil in the intercooler.
18th Apr 2022 2:31pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2714 |
The throttle plate closes on shut down to make sure the engine stops dead so if it’s running on a bit you could have an air leak on the intake side past the TB. The rubber joints on the plenum are known to fail so check for any oily mess around them. 2012 TDV8 Vogue (L322) |
18th Apr 2022 5:29pm |
thats what i got an oilly mess,so bad it leaked into the altarnator at a cost of 600euro ill check those rubbers.
18th Apr 2022 5:43pm |
roel2018 Member Since: 01 Oct 2018 Location: Aalter Posts: 34 |
Lets see in the first week of July what problem creates fault P245A. The LR dealer will check. |
9th Jun 2022 9:25pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
when I had a red DPF warning, on the dash, the engine ran an extra second before shutting down etc. eventually I was able to force a regen, via IID tool, and it went, along with the red light. |
9th Jun 2022 9:49pm |
