Home > Technical (L322) > Strange noise after shutdown 2011 TDV8 4.4 - EGR fault?
roel2018
Netherlands 2017 Range Rover Autobiography SDV8 Carpathian Grey
Hi all,
After push the stop button to shut down, it seems that the engines gives a convulsion or last "puff"with a rattel on the last seconds. It feels that the engine takes more time to stop than normal and simmer.
The motor management light is also visible on the dash and I got some EGR related faults.
Car drives normal. No problems at all.
This fault is different that the standard P041C and P040D:
P245A - Exhaust Gas recirculation cooler - bypass control ciruit
And these one but these are always in the fault list....
P041C - EGR temperature sensor B - circuit low
P040D - EGR temperature sensor A - circuit high
Post #628799 16th Apr 2022 6:28pm
pablo
Ireland 2012 Range Rover Westminster TDV8 Fuji White
Hi paul here in ireland,im wondering did you get to the bottom of the fault as it happens my 2012 4.4 tdv8 as well,plus i have major oil in the intercooler.
let me know.
thanks paul
Post #628977 18th Apr 2022 2:31pm
JayGee
The throttle plate closes on shut down to make sure the engine stops dead so if it’s running on a bit you could have an air leak on the intake side past the TB. The rubber joints on the plenum are known to fail so check for any oily mess around them. 2012 TDV8 Vogue (L322)
Post #628991 18th Apr 2022 5:29pm
pablo
thats what i got an oilly mess,so bad it leaked into the altarnator at a cost of 600euro ill check those rubbers.
thank for the reply.
cheers paul
Post #628992 18th Apr 2022 5:43pm
roel2018
Lets see in the first week of July what problem creates fault P245A. The LR dealer will check. 2017 Range Rover 4.4 SDV8 Autobiography DPF EURO6- 100k miles - Dutch
Post #634212 9th Jun 2022 9:25pm
johnboyairey
when I had a red DPF warning, on the dash, the engine ran an extra second before shutting down etc. eventually I was able to force a regen, via IID tool, and it went, along with the red light.
Post #634213 9th Jun 2022 9:49pm
